KBOX COMMUNICATION WITH KC868-H32B
#33
1. suggest you use DHCP is better. will not have IP conflicts problem. Because sometimes other network device maybe have set the IP address as same as controller's IP.
2. yes, 47.96.253.237 is our free MQTT server's IP, all controller fill with this ip and port.
3. A. Device ID can't be changed ,it's fixed, you can use scan tool to find device's UID and IP address.
B. You should pair each remoter to each controller (not need learn every remote's buttons, it's different from IR, just pair one of remoter's button, then all buttons on the remoter can be used)
4. whether need set momentary function, it's up to you. such as some times maybe one relay have connect with a motor or curtain, momentary function can set the auto off time, it's safety for motor. or some device maybe need pulse, so can enable the momentary function.
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-14-2022, 03:06 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 12:20 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 12:25 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 02:08 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 11:12 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-25-2022, 02:36 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 02-25-2022, 10:45 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-19-2022, 04:25 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-19-2022, 04:29 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-28-2022, 10:59 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 03-01-2022, 10:27 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-01-2022, 11:53 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-02-2022, 01:08 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-08-2022, 02:21 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-22-2022, 08:13 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 07-23-2022, 12:29 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-23-2022, 10:18 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-24-2022, 11:36 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-25-2022, 12:25 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-25-2022, 10:13 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-26-2022, 02:47 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-29-2022, 06:01 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-30-2022, 02:18 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-24-2024, 12:37 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 04-13-2024, 11:32 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-28-2025, 11:57 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 07-21-2025, 09:08 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-21-2025, 09:20 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 07-22-2025, 04:56 AM
