KBOX COMMUNICATION WITH KC868-H32B
#37
(07-24-2022, 11:59 PM)ahmedk4444@yahoo.com Wrote: Last chat with kincony support
We agreed to uae mqtt for all eyhernet controllers and for wifi conyrler TCP server DHCP
H32B is now mqtt for ethernet 47.96.253.237 port 1883
But
Then based on that both D8 don't have wifi only ethernet mqtt static ip 192.168.1.120, 130 port 4196
And using for mqtt 47.96.253.237 port 1883
Status no communication by kbox only remote and one click switch.
Also H32BS mqtt static ip 192.168.1.140 port 4196
Status no communication by kbox also the remote not working i only connect the 12 v input to test and learn remotes yes only one button as you said.
See photos for curremt status and led
Regarding your suggestion for momenty function what does it mean for the momentry time ?
Is it the time of operation until switch off automatically to the desired time?
Or
The time delay to start operation after sent the command?
Hi Admin
If the process choatic because Kincony didn't provide the proper consultstion of the steps clearly!
I asked several times and consult you as a new DIY
What is the steps to start implement my system never come across start with server and home asistance first!
Sending few sentence in steps and links for video and or manual document to follow but be precise to custmized to your client needs and previous discussion.
You must clarify the server installation in details to my case:-
1- will it be mqtt the same ip address for ethernet static and for wifi dhcp tcp server?
2. Please clarify in details to not follow the videos and the setup in the video could be different to my cistomized setup that we discussed many times here and on whatsapp!
3. Important to consider and kincony need hard work on this to run semlessly, we moved to kbox new version 2.02 after Home smart failed to be stabley function and one app working with internet and other without internet, then Kbox upgrade to use for both and pointing me to ethernet through MQTT server in static IP to find the web page of controller and wifi through TCP server DHCP.then you mentioned is Choatic process and you must start with server and home assistance and don't use kbox , then we dropped the home smart app and Kbox and rely only in Home asistance without any simple back up app to use.
Fo you think this the right and proper approach to rely on single system with single setup without back up and moving from one solution to another after exploring troubles with previous advised video and steps for home smart and kbox?!!
I will stop trial any with kincony system and wiring installation until see a proper support to my technical issues.
I spent more than us$ 2000 to replace my current old system that 10 years old and i don't want to be in the same situation again!
I expect from Kincony a proper support and happy to discuss this further through anydesk remotely to save our time and moving forward.
Thank you
Regards
Ahmed
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-14-2022, 03:06 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 12:20 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 12:25 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 02:08 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-18-2022, 11:12 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-25-2022, 02:36 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 02-25-2022, 10:45 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-19-2022, 04:25 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-19-2022, 04:29 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 02-28-2022, 10:59 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 03-01-2022, 10:27 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-01-2022, 11:53 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-02-2022, 01:08 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-08-2022, 02:21 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-22-2022, 08:13 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 07-23-2022, 12:29 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-23-2022, 10:18 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-24-2022, 11:36 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-25-2022, 12:25 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmedk4444@yahoo.com - 07-25-2022, 01:18 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-25-2022, 10:13 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-26-2022, 02:47 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-29-2022, 06:01 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-30-2022, 02:18 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-24-2024, 12:37 AM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 04-13-2024, 11:32 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 03-28-2025, 11:57 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 07-21-2025, 09:08 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by admin - 07-21-2025, 09:20 PM
RE: KBOX COMMUNICATION WITH KC868-H32B - by ahmed - 07-22-2025, 04:56 AM
