Serial command ??
(01-16-2023, 01:15 PM)admin Wrote: i think firstly, you can send RS232 command by PC to test your command whether is correct.
if your command is correct, then try to config by ESPHome to send command.
I know the syntax of commands and I'm sure they work ! My only problem is to get them working with the Kincony through it's RS-232 port !
Can you confirm my ESPHome code is correct ?
Serial command ?? - by vincen - 01-15-2023, 09:24 AM
RE: Serial command ?? - by admin - 01-16-2023, 01:15 PM
RE: Serial command ?? - by vincen - 01-16-2023, 04:06 PM
RE: Serial command ?? - by admin - 01-17-2023, 02:16 AM
