KC868-A32 24VDC input voltage acceptable to Optocopplers?
im currently building a house with automation. While searching I stumbled upen your system wich I really do appreciate cause it looks like exactly what I was looking for. I wanted to start with the A32 for first tests. Question is: in germany we're used to use 24VDC for automation. For the outputs it's not a problem as i will use own couple relais.
Question is:
Are the inputs tolerant to 24VDC? Or can they be if I use additional resistors? Datasheet of the EL357 says 80V is fine but I'm not sure if it is FET inputs and want to be sure before ordering.
Thank you and keep on your good work! Really like!
KC868-A32 24VDC input voltage acceptable to Optocopplers? - by warlord666 - 06-28-2023, 07:38 PM
