KC868-A8 Touch wall panel indication working reverse and temperature sensor
Hi Xu Wei,
Good day, I need assitance for two things.
1. My DHT sensor not reading temperature and the ESPHome log messages output below.
[20:03:03][C][dallas.sensor:075]: DallasComponent:
[20:03:03][C][dallas.sensor:076]:   Pin: GPIO14
[20:03:03][C][dallas.sensor:077]:   Update Interval: 60.0s
[20:03:03][W][dallas.sensor:080]:   Found no sensors!
[20:03:03][C][dallas.sensor:089]:   Device 'study_room_temperature_sensor'
[20:03:03][C][dallas.sensor:089]:     Device Class: 'temperature'
[20:03:03][C][dallas.sensor:089]:     State Class: 'measurement'
[20:03:03][C][dallas.sensor:089]:     Unit of Measurement: '°C'
[20:03:03][C][dallas.sensor:089]:     Accuracy Decimals: 1
[20:03:03][C][dallas.sensor:097]:     Address: 0x1c0000031edd2a28
[20:03:03][C][dallas.sensor:098]:     Resolution: 12
[20:03:55][E][dallas.sensor:112]: Requesting conversion failed
[20:03:55][D][sensor:094]: 'study_room_temperature_sensor': Sending state nan °C with 1 decimals of accuracy
I have tried connecting my DHT11 sensor to both S1 & S2 input terminals and getting the same error for reading the temperature.
2. I am trying to make the Touch Wall Panel Switch glow when turning on inputs, I know KC868-A8 not having a digital input, but i made a small adjustment and patched a wire from relay 1 GND output terminal in the PCB and connected to Switch D1. K1 is connected to input.
All looks good, but the LED is turning ON when the switch 1 is turned off and LED is Off when switch 1 is turned ON.
Connection Details:
A8 Board Input 1 --> Wall Switch K1
A8 Board Relay 1 Digital Input GND soldered from PCB --> Wall Switch D1
A8 Board S1 --> DTH11 Data terminal , VCC and Ground connected in the S1-S4 terminal block VCC & GND.
My ESPHome code block is a below, I tried several 'Inverted : true" at switch component and binalry_sensor component in yaml file, but I am missing some basic part.
Need your help to overcome my Two issues.
  platform: ESP32
  sda: 4
  scl: 5
  encryption:
    key: "********************************************"
ota:
  password: "0fb1fa5d2db965e28cfb201d5afaf06c"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Kc868-A8 Fallback Hotspot"
    password: "************"
captive_portal:
    address: 0x24
    address: 0x22
# Individual outputs
    name: "Study Room Fan"
      pcf8574: pcf8574_hub_out_1
      mode: OUTPUT
      inverted: false
    on_press:
      then:
        - switch.toggle: a8_study_room_fan
      pcf8574: pcf8574_hub_in_1
      mode:
        input: true
dallas:
  - pin: 14
  - platform: dallas
    address: 0x1c0000031edd2a28
.txt   KC868-A8-Touch_Wall_Switch.txt (Size: 1.36 KB / Downloads: 448)
KC868-A8 Touch wall panel indication working reverse and temperature sensor - by vijjav - 07-03-2023, 02:51 PM
