kc868-a32 ethernet problems
I added ota: to it as it is missing. But same errror message:
INFO Successfully compiled program.
INFO Connecting to 192.168.1.183
ERROR Connecting to 192.168.1.183:3232 failed: [Errno 111] Connection refused
Now, the A32 has both wifi and ethernet connections at 183 wired, and 182 wifi. So, I changed the A32 to ESP32-Dev module and tried your script again. This time I got different error message:
ERROR Connecting to 192.168.1.183:3232 failed: [Errno 113] No route to host
but I do not know if the 183 shown in my router is a real wired connection, or something created by your script. Because I did not see the ethernet port on the A32 flashing and I doubt that it is connecting to the router in real mode.
can you convert the above config file into a bin that I can flash via the USB port?
kc868-a32 ethernet problems - by jy1999 - 09-01-2023, 10:41 PM
RE: kc868-a32 ethernet problems - by admin - 09-02-2023, 01:32 AM
RE: kc868-a32 ethernet problems - by jy1999 - 09-02-2023, 02:58 AM
RE: kc868-a32 ethernet problems - by admin - 09-02-2023, 06:58 AM
RE: kc868-a32 ethernet problems - by jy1999 - 09-02-2023, 07:11 AM
RE: kc868-a32 ethernet problems - by admin - 09-02-2023, 07:19 AM
RE: kc868-a32 ethernet problems - by jy1999 - 09-02-2023, 07:31 AM
RE: kc868-a32 ethernet problems - by admin - 09-02-2023, 07:43 AM
RE: kc868-a32 ethernet problems - by jy1999 - 09-02-2023, 07:55 AM
RE: kc868-a32 ethernet problems - by admin - 09-02-2023, 08:54 AM
RE: kc868-a32 ethernet problems - by jy1999 - 09-02-2023, 09:13 AM
RE: kc868-a32 ethernet problems - by NewONE - 11-11-2023, 04:41 AM
RE: kc868-a32 ethernet problems - by admin - 11-11-2023, 08:36 AM
RE: kc868-a32 ethernet problems - by Aclinic - 05-16-2024, 08:32 PM
RE: kc868-a32 ethernet problems - by jy1999 - 05-16-2024, 10:46 PM
