A16 flash problem
#16
(11-21-2023, 10:18 AM)admin Wrote: change another USB cable, lower your baud rate of serial port.
make sure not use USB HUB with your computer, just use USB-C cable connect your board with PC directly.
115200 speed is the lowest that can be selected. The cable is your original. Same thing with another wire. The wire is connected directly to the board, without any transitions. Is it possible to connect remotely? It will take you a few minutes to connect and adopt the settings like a pro.
A16 flash problem - by saint_code - 07-09-2023, 12:50 PM
RE: A16 flash problem - by admin - 07-09-2023, 11:25 PM
RE: A16 flash problem - by saint_code - 07-10-2023, 09:00 AM
RE: A16 flash problem - by admin - 07-10-2023, 11:34 AM
RE: A16 flash problem - by saint_code - 07-10-2023, 12:04 PM
RE: A16 flash problem - by admin - 07-10-2023, 12:29 PM
RE: A16 flash problem - by saint_code - 07-22-2023, 09:49 AM
RE: A16 flash problem - by saint_code - 07-22-2023, 11:14 AM
RE: A16 flash problem - by admin - 07-22-2023, 12:00 PM
RE: A16 flash problem - by zeltini1401 - 11-20-2023, 07:34 AM
RE: A16 flash problem - by admin - 11-20-2023, 10:46 AM
RE: A16 flash problem - by zeltini1401 - 11-20-2023, 03:54 PM
RE: A16 flash problem - by admin - 11-20-2023, 10:30 PM
RE: A16 flash problem - by zeltini1401 - 11-21-2023, 06:01 AM
RE: A16 flash problem - by admin - 11-21-2023, 10:18 AM
RE: A16 flash problem - by zeltini1401 - 11-21-2023, 03:53 PM
RE: A16 flash problem - by admin - 11-21-2023, 11:46 PM
RE: A16 flash problem - by zeltini1401 - 11-22-2023, 06:09 AM
RE: A16 flash problem - by admin - 11-22-2023, 09:51 AM
RE: A16 flash problem - by zeltini1401 - 11-25-2023, 04:52 PM
RE: A16 flash problem - by admin - 11-25-2023, 11:13 PM
RE: A16 flash problem - by zeltini1401 - 11-26-2023, 08:56 AM
RE: A16 flash problem - by admin - 11-26-2023, 11:21 AM
RE: A16 flash problem - by zeltini1401 - 11-27-2023, 10:31 AM
RE: A16 flash problem - by admin - 11-27-2023, 10:45 AM
RE: A16 flash problem - by zeltini1401 - 11-29-2023, 12:38 PM
RE: A16 flash problem - by admin - 11-29-2023, 11:40 PM
