Threads: 0
Why don't you update your system to the latest release?
All new users will experience the same problem
Threads: 1,277
you can delete all "ui-led" on Node-Red, not need to use these node.
Threads: 12
sorry for writing in this old post, but I also have COL and would like to integrate it into HA. I downloaded the file but I can't show COL to node red. is something missing?
Threads: 1,277
are using COL or COLB? do your controller support MQTT?
Threads: 12
I have COL of the same version as your demo. I don't know if it supports mqtt, how can I check?
Threads: 1,277
02-02-2025, 08:58 PM
(This post was last modified: 02-03-2025, 04:54 AM by admin.)
can you use webpage to open config page? or ONLY use vircom tool to set network?
or you can take a photo of your controller.
if you are using KC868-COLB (have BLUE color terminal), that can integrate to home assistant by MQTT. if using KC868-COL (all terminal is GREEN), it's not support mqtt.
Threads: 12
I don't have web pages, I use vircom for the network. the controller is green, identical to the one in the video.
Threads: 1,277
it's old version KC868-COL, it can't integrate to home assistant.
Threads: 12
but it wasn't integrated into the video?
