Threads: 1,591
see this video , you will understand easily.
Threads: 13
11-12-2021, 07:00 PM
(This post was last modified: 11-12-2021, 07:03 PM by ahmed.)
Thanks for last video
As i understood we had 32 terminal blocks input can have bridges if i would like to have a group of one input or separate e2 input to 32 output as a second raw in the terminal block am i correct?
Do you have from HC686-H32B less channel 16B and 8B for the same controller function?
Threads: 13
Back to the maximum current suggest every channel not >3A to use
If the load is 6 A for example can i use 2 input and 2 channel output switch on/ off together to carry the load 6 Amp ? Is it possible ?
Threads: 1,591
switch termoa board , input1 -> output1, input2->output2 .....
if you want input1 customsize link with outputX, you need add KC868-COLB logical controller, that can do your logical set for input trigger output.
yes, H32B,H16B,H8B,H4B,H2B different output version relay controller you can chose.
