Threads: 3
(12-31-2020, 10:36 PM)admin Wrote: OK, you can send me the video, we will check. the new firmware include the bootloader function. so when you power on ,begin 5 seconds, there is wait for bootloader, after 5 seconds controller will begin to work. when you update the new firmware of MCU, next time, you can update firmware by RS232 port , not need to use ST-Link cable again.
Dear Admin I sent for You link for video on private message email.
When should be ready new firmware with bootloader for my PLC ?
Thank You.
Threads: 1,560
hello, we have not received your email, you can send again, these days in China are new year holidays, when we begin work, we will have a look.
Threads: 3
(01-01-2021, 11:31 PM)admin Wrote: hello, we have not received your email, you can send again, these days in China are new year holidays, when we begin work, we will have a look.
Dear admin please look at this video
Starting PLC K868 H32
I saw that is the problem when I turn off supply on short time for example ~ 1 min brake and powered on - then PLC not activated earlier powered outputs and I couldn't activate mannually outputs.
I must disconnect power supply only for PLC ( others modules are powered) and powered on - in this case start working correctly as You see on video.
--- New remarks
After long time - few hours of unpowered (PLC , extended board , RS232 duplicator) - and powered again - PLC start working normally. Is is a problem with short unpowered break.
Threads: 234
can you control the KC868-h32 controller by mobile phone??
Let's check it step by step.
no.1
Threads: 3
(01-05-2021, 01:16 AM)KinCony Support Wrote: can you control the KC868-h32 controller by mobile phone??
no.1 Dear Admin I couldn't check yet because I don't have LAN connection. I must prepare wifi router to check that's the communication. In this week I try to do and confirm.
Threads: 0
i have an elite qubo digital and i also want to know if its upgradable or not, on the side there is a yellow sticker with firmware 80, wk 49-14 written on it. The serial number may be CQ2381 but i am not sure
Thank you for you answer
Threads: 1,560
(01-18-2021, 04:33 AM)Chabeda Wrote: i have an elite qubo digital and i also want to know if its upgradable or not, on the side there is a yellow sticker with firmware 80, wk 49-14 written on it. The serial number may be CQ2381 but i am not sure
H32L not need to update firmware.
Threads: 0
Dear Admin please send the latest firmware for my KC868 H32 PLC.
I have an old version of the 32 Channel Expansion Terminal Light Curtain Wall Switch Panel Board that doesn't work. Do I have to buy a new version and do I need to upgrade the firmware?
Please send for my email matej.radek@seznam.cz
Thank You.
Threads: 1,560
ok, i see, now firmware is sent to your email.
Threads: 3
01-19-2021, 06:52 PM
(This post was last modified: 01-19-2021, 06:53 PM by Kam5.)
Dear Admin for my KC868-H32 firmware what You send to me is with bootloader or not yet ? We wait for new relase ?
I notice few times freezing communication by new button switch module under normal working - when I pressed quickly few times wall swith - plc or button switch board stop working - I couldn't switch on/off anything
I notice few times abnormal working wall switch connected to input on button switch - when I press wall switch for example 1st room to on and 2nd time to off - on other room switch on the light  . It not show on each time but randomly = but always in this same room light on. I checking connections and should be okay.
