Threads: 1,332
maybe you are using the oldest H32 controller.
Threads: 0
Yes, In this case I am using the KC868-H32 L (green removable connectors).
I have added switches on HA dashboard and I can control the lights with this, but I cannot get the switch to update the status if the relay is activated by the terminal board. I have added a TCP in node, but there is no way to send that information back to the boolean switch?
Threads: 0
for those who have the old relay boards, KC868-Hx and the KC868-HxL, there is a way to command the relays through switches on home assistant and have feedback from the physical switches back to the home assistant dash board, without having to install a node red dashboard and with little use of processor of a raspberry pi 3!
Right now I can't post a screenshot, but if anyone needs help, just post a reply and I might be able to help.
Threads: 1,332
email sent, Note: must use ST-link usb cable to update firmware. also have sent the youtube video tour how to update firmware in email.
Threads: 1,332
after you download new firmware , whether control relay is work well?
now what problem? can you take a screen photo?
