Threads: 4
04-27-2023, 06:10 AM
(This post was last modified: 04-27-2023, 06:53 AM by eligijus.)
(04-25-2023, 12:40 AM)admin Wrote: digital input can't use?
your LOG photo, there is error of PCF8574, maybe have set wrong address, please check.
The output doesn't work for me when I press the switch... It works with home assistant and it doesn't work with the switch, although when I press the switch home assistant sees that the input works
(04-27-2023, 06:10 AM)eligijus Wrote: (04-25-2023, 12:40 AM)admin Wrote: digital input can't use?
I want the board's input to function as a push button
Threads: 1,576
if you use by home assistant, this need set in ESPHome, on_press action.
Threads: 4
04-28-2023, 06:19 AM
(04-27-2023, 08:32 AM)admin Wrote: if you use by home assistant, this need set in ESPHome, on_press action.
Maybe you can upload information on how to do this, please
Threads: 1,576
Threads: 4
04-30-2023, 03:33 PM
(04-29-2023, 02:41 AM)admin Wrote: you can see here: https://esphome.io/guides/automations.html#automation
hello, I tried to write but it doesn't work, I get errors, maybe you can write at least one channel example so that it works
Threads: 1,576
05-01-2023, 12:36 AM
(This post was last modified: 05-01-2023, 12:58 AM by admin.)
you can check this home assistant forum topic, it's you need:
https://community.home-assistant.io/t/pu...how/112361
Threads: 4
(05-01-2023, 12:36 AM)admin Wrote: you can check this home assistant forum topic, it's you need:
I understand that there are different types of people here, but I can't write error-free code because I'm not a programmer. I am an electrician and I bought 4 pcs KC868-A16 and KC 868-AP automation for the whole house. Please write the code for the push button dimmer
Threads: 1,576
ok, when we have free time, we can test for that.
Threads: 4
(05-01-2023, 11:44 PM)admin Wrote: ok, when we have free time, we can test for that.
I'm waiting, when do you have time?
Threads: 1,576
