"KCS" v1.0.24 firmware BIN file download
#11
yes, in furture will add it.
after flash my KCS_KC868- AK with KCS_KC868_AK_V1.0.24.zip, the KCS_KC868_AK has stopped communicating with the KC868-H32B-PRO via RS232 and RS485, now when I press the buttons on the KCS_KC868_AK, the relays are not activated on the KC868-H32B-PRO, how do I get it working again?
yes, "KCS" is another firmware for KC868-AK.
if you want to use by H32B Pro , suggest use before firmware is better. here is download link:
.zip   kc868-ak-v1.0.7.zip (Size: 453.15 KB / Downloads: 615)
(04-05-2023, 10:48 AM)admin Wrote: Here is "KCS" firmware for KinCony KC868-A series (ESP32) board.
How to download and use, online guide: https://www.kincony.com/kcs-firmware-esp32-board.html
v1.0.24 improment:
1. Fix some text in webpage.
2. Fix timer bug for different channel reset problem.
3. Let MQTT message feedback only one time, before will be twice.
4. Support RS485 MODBUS Button Adapter – KC868-HA
5. Fix bug of DAC output with tuya app problem.
what is suitable firmware for KC868-E16T ?
you can download with E16S' , but after you download, your E16T tuya wifi module will not work.
In manual says that OUTPUT delay time may be 1 - 255 x 100ms, but I need a 20 minutes delay. How can I implement this?
if 20 minutes, go to "schedule" webpage, create "schedule" for it.
I need to disable OUTPUT in 20min after disabling INPUT.
I tried schedule section, but I cant find any way to start time counting after disabling INPUT, or any other ways to use inputs as trigger for schedules.
Can you explain the solution with schedules?
i am not understand your question, maybe you can draw a photo?
For example:
If I single-click INPUT1, then OUTPUT1 turns on. After 20 minutes, OUTPUT1 should turn off automatically.
