Threads: 1,560
"one terminal pole per lamp" is ok.
Threads: 0
I'm planning to install Smart Home System for my home. Been considering it for 1 year+ now. I’ve made my research and find that KinCony suites my needs as I can customise base on my needs.
List below are the equipment/appliances that I wish to control
Living Room
1. Light – 3 nos
2. Ceiling Fan – 1 no. (Ceiling Fan c/w Light)
3. TV (Supply for DB2) – OPTIONAL
4. IP Camera
Master Bedroom
1. Ceiling Fan – 1 no. (Ceiling Fan c/w Light)
2. Aircon – 1 no.
3. Toilet Light – 1 no.
4. Heater – 1 no.
5. Exhaust Fan – 1 no.
Bedroom 2
2. Aircon – 1 no.
Bedroom 3
2. Aircon – 1 no.
Kitchen/Dining
1. Light – 2 nos.
2. Wall Fan – 1 no. (Supply for DB2) – OPTIONAL
3. Exhaust Fan (to control via Power Socket)
4. Cut-off Valve for Gas Line (to control via Power Socket)
Common Toilet
1. Light – 1 no.
2. Heater – 1 no.
3. Exhaust Fan – 1 no.
Control System
- Ethernet / WIFI
- Home Assistant to control from Phone
- Control devices using Siri (preferred), Alexa or Google
- Control devices from Internet (WAN)
- Bypass Smart Home (can use traditional way of switching)
Size:
- Single Floor Unit
- Light Switch with 1 power source from DB from each room
- Switch Socket Outlet – Looping for 1 MCB for each room
- Internet @ 2Gbps located near Main DB
Appreciate your kind assistance and Thank you in advance.
ps: How can I attach Single Line Diagram and Layout Plan?
Threads: 1,560
i think you can use KC868-H32B Pro relay controller for ON/OFF devices.
KC868-AG Pro for air conditioner.
IP camera you can chose any TUYA solution product.
if you want control fan speed, you can add KC868-D16 dimmer controller + SSR for AC220V load.
KC868-Server to install home assistant software.
Threads: 1,560
ok, no problem, just post at here.
