Threads: 1
Received the A16 Controller board yesterday. It looks OK, but the shipment did not contain any documentation.
For proper testing and configuring the board with ESPHome, please provide me with the A16-board hardware <-> ESP32-GPIO pin relation specification:
a16 board input1,2,3 -> 16 = gpio x1, x2, x3 etc. to x16.
a16 board analogue inputs 1--->4 = gpio y1,y2,y3,y4;
a16 board I2C pins= gpios ….
a16 board Free gpios 1->3= …..
a16 board RF 433 MHz: pin tx gpio= gpio.. and rx= gpio …
a16 board Ethernet pin(s)= gpio ….
a16 board USB pins= gpio ...
Also needed advice: which ESPHome configuration file is best to start with for the a16 board?
thx in advance
Threads: 1
The example is limited and incomplete. I need a complete list of A16-board and GPIO relations.
Threads: 1,528
every model in our forum have esphome yaml demo. you can check , some have analog input, some have ds18b20 gpio temperature sensor, some have RF 433MHz sender and receiver. you can use for it. i don't know except DO and DI, which hardware resource you will use?
Threads: 1
Tried to download the ESPHome configuration YAML file to my newly acquired KC868-A16 board.
But no luck so far after 2 days of hard trying. I produced the required YAML file on my existing Home Assistant platform on a Windows computer, using your demo files. They were validated as OK and also compiled well. Tried to do download via a) the server pc with Home Assistant running on it b) via another PC with browser access to Home Assistant and c) manually via ESP32 Dowmload Tool v 9.3.5. In all cased the USB-connection could be established, bust the download failed completely. The logging of the ESP32 download tool indicated: 'no XMC flash detected' and: :esp32 chip dopwnload error". Is this A16 board possibly not OK? Please advise.
Threads: 1,528
take a photo of your A16 PCB board when work for download.
Threads: 1
Thx, an excellent advise.
Now I could ‘normally download’ and configure the board with ESPHome file(s).
Question: can I now also put back the 2 RF-modules and still being able to do further configurations without problems?
Threads: 1,528
just when download firmware remove the RF module, after download , you can install them on PCB.
