AS ESPHome yaml for home assistant
#11
"Is it possible that in 1 yaml file to program bought gpio15 an gpio 16 leds?" what this means? you can control both LED with GPIO15 and GPIO16, it's OK.
I recently purchased and setup the KinCony Voice Assistant device. Works great, but the volume from the speaker is too low to hear. How can I increase the volume from the speaker?
if you use ESPHome, you can set the volume in yaml file.
(12-02-2024, 10:59 PM)admin Wrote: if you use ESPHome, you can set the volume in yaml file.
Could you give me an example? I've searched online, but don't see any examples of increasing the volume in the yaml file.
see here in details: https://esphome.io/components/speaker/index.html
Hi all,
I have my working configuration here, also using media player:
  friendly_name: Assistant 1
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    - light.turn_on:
        blue: 100%
        brightness: 60%
        effect: fast pulse
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: esp-idf
    sdkconfig_options:
      CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: "y"
      CONFIG_ESP32S3_DATA_CACHE_64KB: "y"
      CONFIG_ESP32S3_DATA_CACHE_LINE_64B: "y"
      CONFIG_AUDIO_BOARD_CUSTOM: "y"
external_components:
  - source: github://pr#7672
    components:
      - audio
      - speaker
      - i2s_audio
      - speaker
    refresh: 0s
psram:
  mode: octal  # quad for N8R2 and octal for N16R8
  speed: 80MHz
  encryption:
    key: "*********************************************"
  on_client_connected:
    then:
      - delay: 50ms
      - light.turn_off: notify_center
      - micro_wake_word.start:
  on_client_disconnected:
    then:
      - voice_assistant.stop:
ota:
  - platform: esphome
    password: "****************************************"
wifi:
  ssid: !secret wifi_ssid
  fast_connect: True
  ap:
    ssid: "Assistant1 Fallback Hotspot"
    password: "********************************"
web_server:
  port: 80
captive_portal:
button:
  - platform: restart
  - platform: template
    on_press:
      then:
        - voice_assistant.start
    name: "Start continious assist"
    on_press:
      then:
        - voice_assistant.start_continuous:
    on_press:
      then:
    optimistic: true
    on_turn_on:
      - micro_wake_word.stop:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
      - light.turn_on:
          red: 100%
          green: 0%
          blue: 0%
          brightness: 30%
    on_turn_off:
      - light.turn_on:
          red: 0%
          green: 100%
          blue: 0%
          brightness: 60%
          effect: fast pulse
      - delay: 2s
      - light.turn_off:
light:
  - platform: esp32_rmt_led_strip
    rgb_order: RGB
    pin: GPIO16
    num_leds: 1
    rmt_channel: 0
    chipset: ws2812
    effects:
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
    rgb_order: GRB
    pin: GPIO15
    num_leds: 3
    rmt_channel: 1
    chipset: ws2812
    effects:
      - pulse:
      - pulse:
          min_brightness: 0%
      - addressable_color_wipe:
      - addressable_scan:
          move_interval: 300ms
          scan_width: 1
      - addressable_scan:
          name: Scan Effect 2
          move_interval: 800ms
          scan_width: 1
# Audio and Voice Assistant Config
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO3  #WS
    i2s_bclk_pin: GPIO2 #SCK
  - id: i2s_speaker
    i2s_lrclk_pin: GPIO6  #LRC
    i2s_bclk_pin: GPIO7 #BLCK
microphone:
  - platform: i2s_audio
    adc_type: external
    i2s_din_pin: GPIO4 #SD pin on the INMP441
    channel: left
    pdm: false
    i2s_audio_id: i2s_in
    bits_per_sample: 32 bit
speaker:
    platform: i2s_audio
    i2s_audio_id: i2s_speaker
    dac_type: external
    i2s_dout_pin: GPIO8  #  DIN Pin of the MAX98357A Audio Amplifier
    channel: left
    sample_rate: 48000
media_player:
  - platform: speaker
    name: "Assistent media player"
    speaker: va_speaker
    sample_rate: 48000
    on_play:
      - logger.log: "Playback started!"
      - light.turn_on:
          red: 30%
          green: 30%
          blue: 0%
          brightness: 100%
    on_idle:
      - logger.log: "Playback finished!"
      - light.turn_off: notify_lower
micro_wake_word:
  on_wake_word_detected:
    then:
    - voice_assistant.start:
        wake_word: !lambda return wake_word;
  models:
    - model: github://esphome/micro-wake-word-models/models/v2/okay_nabu.json
voice_assistant:
  microphone: va_mic
  noise_suppression_level: 2.0
  volume_multiplier: 4.0
  media_player: speaker_media_player_id
  on_start:
    - light.turn_on:
        red: 30%
        green: 30%
        blue: 70%
        brightness: 60%
        effect: fast pulse
    - media_player.volume_set: 100%
  on_stt_end:
  on_error:
  on_end:
    - wait_until:
        not:
          voice_assistant.is_running:
  on_tts_start:
    - light.turn_on:
        red: 0%
        green: 30%
        blue: 0%
        brightness: 60%
        effect: fast pulse
  on_tts_end:
    - delay: 2s
May help someone, it took me 3 days to make it working
Thank you very much share your config file to help people.
(12-05-2024, 11:21 PM)admin Wrote: see here in details: https://esphome.io/components/speaker/index.html
So I have this file:
/homeassistant/esphome/kincony-as.yaml
and I've modified the speaker section to:
speaker:
    platform: i2s_audio
    volume: 90%
    dac_type: external
    channel: mono
Then did a quick reload of the YAML, then restarted Home Assistant, but no change in volume.
Is there something else I need to do please?
Think my previous reply was not following the example, so also tried this:
speaker.volume_set: 90%
and this:
speaker.volume_set:
    volume: 90%
Still no change
sure, you can control GPIO15 and GPIO16 different LEDs. see this demo video: https://www.youtube.com/shorts/59CFvpFJMdc
2 Guest(s)
