Threads: 7
I have the right firmware
All this has already been done.
I use static IPs!
And so there is the same IP since we cannot configure two different ones
Board : K868-A16
Firmware : v2.2.12
Threads: 1,546
you can set DHCP for testing.
Threads: 0
Hello
I have also the KC868-A16 with the v2.2.10 firmware and I have the same problem.
As soon as I made any changes and system has to restart the Ethernet port stops to communicate with the switch (led on the switch turns off) and I have to disconnect the supply to the board and reconnect it in order to connect to the card.
I have also turn wifi off but no change.
Threads: 7
Yes I agree, but it is not normal it must take one of the networks.
The ideal is an IP by type of media.
For me the reliability remains the Lan
Board : K868-A16
Firmware : v2.2.12
Threads: 7
I was away, no response from the admin on the subject?
Board : K868-A16
Firmware : v2.2.12
