KinCony Z1 Problem
#11
you can test with new firmware: https://www.kincony.com/forum/showthread.php?tid=9112
fixed undecoded IR signal are currently being reported to Home Assistant via MQTT.
Thanks, infrared is working great, the resets are gone too. Only Zigbee still doesn't work — it detects the device with a beep but doesn't add it to the list, and the device itself behaves as if it were connected. (the devices I'm testing are 100% Zigbee 3.0)
some zigbee3.0 is not a standard protocol. if you want, we can send you a kincony zigbee3.0 sensor to test.
OK, please. How do we handle this, AliExpress?
kincony zigbee3.0 senosr at here: https://shop.kincony.com/collections/ele...ies?page=4
2 Guest(s)
