N60 Sensor channel label
#11
(Yesterday, 04:05 AM)admin Wrote: 1: about "power factor" we will check and later feedback to you.
2: here is new KCS firmware, support rename for every channel and update to home assistant by mqtt auto discovery.
just double click the channel name, you can rename by yourself.
firmware BIN file download:
Thank you!!
1: the "power factor" according to channel1. BL0910 chip only have one channel power factor, can't monitor 10 channels.
(2 hours ago)admin Wrote: 1: the "power factor" according to channel1. BL0910 chip only have one channel power factor, can't monitor 10 channels.
Ok, thank you for checking.
Can you tell me if there is a procedure to properly calibrate  the measurements on each of the channels?
