Threads: 234
(01-19-2021, 06:52 PM)Kam5 Wrote: (12-31-2020, 10:36 PM)admin Wrote: OK, you can send me the video, we will check. the new firmware include the bootloader function. so when you power on ,begin 5 seconds, there is wait for bootloader, after 5 seconds controller will begin to work. when you update the new firmware of MCU, next time, you can update firmware by RS232 port , not need to use ST-Link cable again.
Dear Admin for my KC868-H32 firmware what You send to me is with bootloader or not yet ? We wait for new relase ?
I notice few times freezing communication by new button switch module under normal working - when I pressed quickly few times wall swith - plc or button switch board stop working - I couldn't switch on/off anything
I notice few times abnormal working wall switch connected to input on button switch - when I press wall switch for example 1st room to on and 2nd time to off - on other room switch on the light
. It not show on each time but randomly = but always in this same room light on. I checking connections and should be okay.
can you add my WhatsApp +8613336170682.
Threads: 0
Dear Admin,
Please send me the latest firmware for KC868-H32. The button switch module do not work with my old H32.
My email salexs@inbox.lv
Thank You.
Threads: 234
01-22-2021, 01:33 AM
(This post was last modified: 01-22-2021, 01:42 AM by KinCony Support.)
(01-20-2021, 09:21 PM)salexs Wrote: Dear Admin,
Thank You.
can you take a picture of you controller?
Thank You.
Add my WhatsApp +8613336170682
Threads: 4
01-23-2021, 07:18 PM
Hello KinCony managers and engineers, why you not update your pages with new firmwares, with declared version numbers, date of issue and improvements description.
Why your customers who bought your controllers need ask to send it on their private mails.
Does it mean: who did not ask did not even receive...
So cool
Threads: 1,322
01-28-2021, 12:11 PM
(This post was last modified: 01-28-2021, 12:12 PM by admin.)
firmware no problem, we have helped him by teamviewer found the problem that not use the correct firmware download tool.
Threads: 0
Hello i have a KC868-H32 , i can´t access in server mode only in UDP by a remote access in my phone.
i use your vircom, dhcp and TCP server mode, put the ip in your KC868-H32 pc software but don´t acess
i Whant to integrete whith home assistent.
Threads: 1,322
if you set controller in TCP Server mode, in PC software also need set work mode=LAN.
if integrate with home assistant, you can check videos how to do in our youtube channel.
Threads: 0
Hello From Belgium,
could you please send me the actual firmware for the KC868-H32W? Actually i am on 4.13 and it doesn´t support MQTT Mode.
Email: marcelsgarage09@gmail.com
thank you!
Threads: 1,322
sorry, because of the hareware resource, only KC868-H32B support MQTT.
