KC868-A16S configure yaml for ESPhome
#21
Hi,
I use kc868 a16s with esphome in home assistant based on this config example.
While updating esphome I get several warnings, at least one warning will be an error from 2026 on. Plz see log attachment.
Relevant warnings:
- WARNING IMPORTANT: This device doesn't have a framework specified! (Currently, ESP32 defaults to the Arduino framework. This will change to ESP-IDF in ESPHome 2026.1.0.)
- WARNING: The 'clk_mode' option is deprecated and will be removed in ESPHome 2026.1. Please update your configuration to use 'clk' instead.
- WARNING DEPRECATED: 'esptool.py' is deprecated. Please use 'esptool' instead. The '.py' suffix will be removed in a future major release.
I would be very grateful if you could update the example configuration to meet the actual requirement.
Thanks in advance.
Andreas
.txt   logs_kc868-a16s.txt (Size: 7.5 KB / Downloads: 332)
in future will update when can't compile. now just a warning.
Where is the 1-wire config?
do you use by esphome or KCS firmware?
