  • 1 Vote(s) - 5 Average
New DIY Project Support
#31
please revise something wrong i made
  platform: ESP32
  board: esp32dev
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
pcf8574:
    address: 0x24
  - id: 'pcf8574_hub_out_2'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_3'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_4'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_5'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_6'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_7'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_8'  # for output channel 1-8
    address: 0x24
  - id: 'pcf8574_hub_out_9'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_out_10'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_out_11'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_out_12'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_out_13'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_out_14'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_out_15'  # for output channel 9-16
    address: 0x25
  - id: 'pcf8574_hub_out_16'  # for output channel 9-16
    address: 0x25
    address: 0x21
  - id: 'pcf8574_hub_in_2'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_3'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_4'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_5'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_6'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_7'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_8'  # for input channel 1-8
    address: 0x21
  - id: 'pcf8574_hub_in_9'  # for input channel 9-16
    address: 0x22
  - id: 'pcf8574_hub_in_10'  # for input channel 9-16
    address: 0x22
  - id: 'pcf8574_hub_in_11'  # for input channel 9-16
    address: 0x22
  - id: 'pcf8574_hub_in_12'  # for input channel 9-16
    address: 0x22
  - id: 'pcf8574_hub_in_13'  # for input channel 9-16
    address: 0x22
  - id: 'pcf8574_hub_in_14'  # for input channel 9-16
    address: 0x22
  - id: 'pcf8574_hub_in_15'  # for input channel 9-16
    address: 0x22
  - id: 'pcf8574_hub_in_16'  # for input channel 9-16
    address: 0x22
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      # Use pin number 0
      # One of INPUT or OUTPUT
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_2
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_3
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_4
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_5
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_6
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_7
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_8
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_out_9
      # Use pin number 0
      mode: OUTPUT
      inverted: false
      pcf8574: pcf8574_hub_in_1
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_2
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_3
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_4
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_5
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_6
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_7
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_8
      # Use pin number 0
      mode: INPUT
      inverted: false
      pcf8574: pcf8574_hub_in_9
      # Use pin number 0
      mode: INPUT
      inverted: false
.pdf   ESP Home configuration from 1 to 9 only .pdf (Size: 180.1 KB / Downloads: 623)
what's your router's ip address?
192.168.1.1
because you download is demo config for output 1-9. you can download this config file, it have fully 1-16 channel.
.txt   Made_for_ESPHome_KC868-A16.txt (Size: 5.6 KB / Downloads: 506)
  platform: ESP32
  board: esp32dev
  sda: 4
  scl: 5
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  manual_ip:
pcf8574:
    address: 0x24
    address: 0x25
    address: 0x21
    address: 0x22
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      mode: OUTPUT
      number: 1
      mode: OUTPUT
      number: 2
      mode: OUTPUT
      number: 3
      mode: OUTPUT
      number: 4
      mode: OUTPUT
      number: 5
      mode: OUTPUT
      number: 6
      mode: OUTPUT
      number: 7
      mode: OUTPUT
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
      mode: INPUT
      number: 1
      mode: INPUT
      number: 2
      mode: INPUT
      number: 3
      mode: INPUT
      number: 4
      mode: INPUT
      number: 5
      mode: INPUT
      number: 6
      mode: INPUT
      number: 7
      mode: INPUT
Thank you , here is the download log after install to check( attached)
Only input from 1-9 and unavilable not to 16 as well
And light from 1-16 and not seen on the card although i added several times.
See attached.
What i should do next mandatory before start setting up H32B?
I had apointment with electrician tomorrow morning to install the DB of outdoor that has the H32B and the teminal switch board and still until now working on MQTT through kbox and activate both 2 remote controls before starting to install the server and A16
Let me ask 3 important questions:-
1- what is mandatory to setup as a hardware and software as well as installation prior to setup H32B on the home asistance? And is it okay after connect to the load to change setting from Mqtt static ethernet snd wifi dhcp to mqtt dhcp ethernet through home asisstant and dtop the wifi?
2- how the system work and dependently on power supplies, i mean the server, A16, router, controllers all connected to normal suppy foes all of those connected to ups in case power failed to keep the system controllable?
3- i made most of my stetup for installation on my laptop, i want afterwords to reinstall the windows and re-image my apps and application what i need to re- setup again on the laptop from previous steps.
Please give me the main headlines and steps in correct sequence for what is mandatiry to do first before start configure the controllers and i can with time improve the other steps to check the system before start connected to load and be in service.
Thank you
Thank you again for help and support
.txt   logs_kc868-a16_upload.txt (Size: 18.58 KB / Downloads: 519)
See attached.
Thank you
Home assistant is still not working out of house network on 4G mobile App !!!
please see clearly the new config file:
not "input1"
delete your entities in dashboard, re add entities
Yes this exactly a16-input as the file replaced
Do you understand me ?  but in your home assistant dashboard, not used new id name.
