Threads: 1,385
can you take a photo of your error.
Threads: 1
I try home assistant ad on esphome
But asking host and port I am using A16 board
Please help me for this
Threads: 1,385
if you have problem, need post details.
Threads: 1
I have zimaboard server with home assistant software
I'n home assistant I try to add esphome
Then there is 2 option in that form
1 is host
2 is port
So what I have to fill in this for adding esphome
Thank you so much for replying
Threads: 1,385
host is your board's ip address, port is 6053 in ESPHome.
Threads: 1
Thank you very much sir I try as you said
But comming this error
Can't connect to ESP. Please make sure your YAML file contains an 'api:' line.
Threads: 1,385
esphome have already told you : you need add "api:" to yaml file line.
Threads: 1
08-04-2023, 10:03 AM
(This post was last modified: 08-04-2023, 10:06 AM by reehanlambe.)
Hi sir I need your help
How to use api key in A 16 BOARD yaml file for esphome
Thanks
Threads: 1,385
very very easy, just add
to your config yaml file.
