Threads: 1,549
that need to use tuya license.
Threads: 1
(10-13-2025, 10:18 AM)admin Wrote: that need to use tuya license.
I have license for KC868-A6
I use example in GitHub - hzkincony/esphome-tuya-iot
change ref: v1.2.0 to ref: v1.2.1
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-tuya-iot
ref: v1.2.1
and get error in
src/esphome/components/tuya_iot/tuya_iot_component.cpp: In member function 'virtual void esphome::tuya_iot::TuyaIotComponent::update()':
src/esphome/components/tuya_iot/tuya_iot_component.cpp:292:19: error: 'esp_mqtt_client_config_t' {aka 'struct esp_mqtt_client_config_t'} has no member named 'username'
292 | mqtt_cfg_.username = username;
my mqtt correct
mqtt:
broker: !secret mqtt_host
username: !secret mqtt_username
password: !secret mqtt_password
Threads: 1
есть какие-то идеи, как исправить ошибку?
Threads: 1,549
post your yaml file at here.
Threads: 1
(02-20-2026, 02:10 AM)admin Wrote: post your yaml file at here.
Code: # Basic Config
friendly_name: KC868_A6_Test
# platform: ESP32
# board: esp32dev
- source:
type: git
ref: v1.2.1
esp32:
board: esp32dev
framework:
# type: esp-idf
# type: arduino
type: arduino # Важно изменить на arduino
version: latest
encryption:
key: "mdhQnkxHuyHBBOp3c+vVZw1mijHvK6GlGVDXbwhzSMM="
mqtt:
ota:
- platform: esphome
# password: "5992f85d33c321fdc84443dbf6d1eab2"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Kc868-A6-Test Fallback Hotspot"
password: "iuUkzi7OQNef"
captive_portal:
time:
- platform: homeassistant
sda: 4
scl: 15
# Example configuration entry
pcf8574:
address: 0x24
address: 0x22
# Individual outputs
on_turn_on:
- lambda: !lambda |-
id(tuya_iot_component).property_report("output1", true);
on_turn_off:
id(tuya_iot_component).property_report("output1", false);
pcf8574: pcf8574_hub_out_1
mode: OUTPUT
on_turn_on:
id(tuya_iot_component).property_report("output2", true);
on_turn_off:
id(tuya_iot_component).property_report("output2", false);
number: 1
mode: OUTPUT
on_turn_on:
id(tuya_iot_component).property_report("output3", true);
on_turn_off:
id(tuya_iot_component).property_report("output3", false);
number: 2
mode: OUTPUT
on_turn_on:
id(tuya_iot_component).property_report("output4", true);
on_turn_off:
id(tuya_iot_component).property_report("output4", false);
number: 3
mode: OUTPUT
on_turn_on:
id(tuya_iot_component).property_report("output5", true);
on_turn_off:
id(tuya_iot_component).property_report("output5", false);
number: 4
mode: OUTPUT
on_turn_on:
id(tuya_iot_component).property_report("output6", true);
on_turn_off:
id(tuya_iot_component).property_report("output6", false);
number: 5
mode: OUTPUT
pcf8574: pcf8574_hub_in_1
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
#switch:
# - platform: gpio
# pin: 25
# name: "switch test 1"
# id: switch_test_1
# on_turn_on:
# - lambda: !lambda |-
# id(tuya_iot_component).property_report("output1", true);
# on_turn_off:
# id(tuya_iot_component).property_report("output1", false);
# - platform: gpio
# pin: 26
# name: "switch test 2"
# id: switch_test_2
# on_turn_on:
# id(tuya_iot_component).property_report("output2", true);
# on_turn_off:
# id(tuya_iot_component).property_report("output2", false);
tuya_iot:
product_id: xp***lm
device_id: 26***3j
device_secret: H***w
region: eu # eu, us, eus, weu, in, cn
# eu: Central Europe Data Center
# us: US West Data Center
# eus: US East Data Center
# weu: Western Europe Data Center
# in: India Data Center
# cn: Chinese Data Center
on_event:
- event_name: property/set
then:
// Append the required switch in switch_map to respond to commands issued by Tuya.
static std::map<float, switch_::Switch*> switch_map {
{ 1, id(light1) },
{ 2, id(light2) },
{ 3, id(light3) },
{ 4, id(light4) },
{ 5, id(light5) },
{ 6, id(light6) },
bool is_target_output = false;
bool output_state = false;
int output_number = 0;
// Modify this number 2 to match the number of switches in the above switch_map.
for (int i = 1; i <= 6; i++) {
String key = "output" + String(i);
if (x.containsKey("data") && x["data"].containsKey(key.c_str())) {
is_target_output = true;
output_state = x["data"][key.c_str()];
output_number = i;
break;
if (is_target_output) {
auto iterator = switch_map.find(output_number);
if (iterator != switch_map.end()) {
auto sw = iterator->second;
if (output_state) {
sw->turn_on();
} else {
sw->turn_off();
bool is_target_all_on = false;
bool all_on_state = false;
if (x.containsKey("data") && x["data"].containsKey("all_on")) {
is_target_all_on = true;
all_on_state = x["data"]["all_on"];
if (is_target_all_on) {
if (all_on_state) {
for(const auto& pair : switch_map) {
auto sw = pair.second;
sw->turn_on();
bool is_target_all_off = false;
bool all_off_state = false;
if (x.containsKey("data") && x["data"].containsKey("all_off")) {
is_target_all_off = true;
all_off_state = x["data"]["all_off"];
if (is_target_all_off) {
if (all_off_state) {
sw->turn_off();
Threads: 1,549
i have updated esphome-tuya-iot plugin to 1.2.2 so need to modify yaml:
1: esp32 framework MUST use esp-idf
2. on_event lambda changed.
you can test with this new yaml modified.
# platform: ESP32
# board: esp32dev
- source:
type: git
ref: v1.2.2
esp32:
board: esp32dev
framework:
# type: esp-idf
# type: arduino
type: esp-idf # Важно изменить на arduino
version: latest
encryption:
mqtt:
ota:
- platform: esphome
wifi:
ap:
captive_portal:
time:
sda: 4
scl: 15
pcf8574:
address: 0x24
address: 0x22
on_turn_on:
on_turn_off:
mode: OUTPUT
on_turn_on:
on_turn_off:
number: 1
mode: OUTPUT
on_turn_on:
on_turn_off:
number: 2
mode: OUTPUT
on_turn_on:
on_turn_off:
number: 3
mode: OUTPUT
on_turn_on:
on_turn_off:
number: 4
mode: OUTPUT
on_turn_on:
on_turn_off:
number: 5
mode: OUTPUT
mode: INPUT
number: 1
mode: INPUT
number: 2
mode: INPUT
number: 3
mode: INPUT
number: 4
mode: INPUT
number: 5
mode: INPUT
#switch:
# - platform: gpio
# pin: 25
# id: switch_test_1
# on_turn_on:
# on_turn_off:
# - platform: gpio
# pin: 26
# id: switch_test_2
# on_turn_on:
# on_turn_off:
tuya_iot:
product_id: xp***lm
device_id: 26***3j
on_event:
then:
{ 1, id(light1) },
{ 2, id(light2) },
{ 3, id(light3) },
{ 4, id(light4) },
{ 5, id(light5) },
{ 6, id(light6) },
std::string key = "output" + std::to_string(i);
if (x["data"][key].is<bool>()) {
output_state = x["data"][key].as<bool>();
output_number = i;
break;
if (output_state) {
sw->turn_on();
} else {
sw->turn_off();
if (x["data"]["all_on"].is<bool>()) {
all_on_state = x["data"]["all_on"].as<bool>();
if (all_on_state) {
sw->turn_on();
if (x["data"]["all_off"].is<bool>()) {
all_off_state = x["data"]["all_off"].as<bool>();
sw->turn_off();
new yaml download:
a6-test-new.txt (Size: 8.04 KB / Downloads: 234)
Threads: 1
Спасибо. Теперь возник вопрос, как устройство добавить в SmartLife/Tuya приложение. Ранее добавлял через QR-код, который формировался в KCS прошивке.
А как получить QR-код для прошивки, написанной в ESPHome?
Threads: 1,549
do you have bought tuya license, we have send you "bind code" by email. you can use qrcode online guide, convert the "bind code" to qrcode. if you don't know how to make qrcode. you can send us your "bind code", we create qrcode for you.
Threads: 1
Send to web@kincony.com my license
"qrcode online guide" - post link?
Threads: 1,549
