  • 1 Vote(s) - 5 Average
"KCS" v2.2.2 firmware BIN file download
#41
which sensor model you are using? do you use DHT11?
you can try to test with thie firmware for KC868-AM
.zip   KCS_KC868_AM_V2.2.3.zip (Size: 746.45 KB / Downloads: 747)
(06-14-2024, 04:42 AM)admin Wrote: which sensor model you are using? do you use DHT11?
All Sensors are ds18b20. V2.2.3 does not help. Results are the same.
take a video of your board how you test, so that can understand your problem. video send to whatsapp number: +86-15381188302
Don't use  WhatsApp. I have attached two pictures of my configuration. Works fine with ESPHome, but I want to use KCS firmware because I like the extra features it has.
I have noticed in MQTT Explorer that the published MQTT string has an extra comma before "output1".  {,"output1":{"value":true},"sensor1":{"temperature":78.3,"humity":-100.0},"sensor2":{"temperature":78.8,"humity":-100.0},"sensor3":{"temperature":78.6,"humity":-100.0},"sensor4":{"temperature":78.6,"humity":-100.0}}
This seems to affect the JSON format so I don't know if it is supposed to be there or is it a bug in the firmware.
I have circled it in red in the image.
ok, i see now, we will check, update firmware.
do you use 3pcs of DS18B20 with 3 GPIOs?
I have 4 connected.
test this firmware for KC868-AM, then tell me result.
.zip   KCS_KC868_AM_V2.2.4.zip (Size: 746.37 KB / Downloads: 713)
You left out the comma between false} and "sensor1"
{"output1":{"value":false}"sensor1":{"temperature":83.3,"humity":-100.0},"sensor2":{"temperature":82.8,"humity":-100.0},"sensor3":{"temperature":82.6,"humity":-100.0},"sensor4":{"temperature":86.9,"humity":-100.0}}
Are you going to respond to my message about the format error that still exists?
use this one:
.zip   KCS_KC868_AM_V2.2.4.zip (Size: 746.33 KB / Downloads: 687)
tested as photo:
{"output1":{"value":false},"sensor1":{"temperature":28.2,"humity":-100.0},"sensor2":{"temperature":-100.0,"humity":-100.0},"sensor3":{"temperature":-100.0,"humity":-100.0},"sensor4":{"temperature":-100.0,"humity":-100.0}}
if have value -100.0 that means sensor not connected.
