Threads: 1,578
Can I use 24V on the kc868-HA? Yes, no problem.
we will update KC868-HA plugin for home assistant soon. that will support new firmware. so that can detect ON/OFF two state in home assistant , work as a BINARY sensor.
Threads: 0
10-06-2023, 02:54 PM
(This post was last modified: 10-06-2023, 04:23 PM by NicTheModder.)
(10-06-2023, 12:44 AM)admin Wrote: Can I use 24V on the kc868-HA? Yes, no problem.
Super!
Looking forward :-)
Can you make 'kc868_component' work side by side with 'modbus_controller' ? Now it gives often:
[18:15:10][W][modbus:108]: Modbus CRC Check failed! 960!=10C
[18:15:10][W][modbus:108]: Modbus CRC Check failed! 20!=00
[18:15:10][W][modbus:108]: Modbus CRC Check failed! C071!=00
[18:15:14][W][modbus:108]: Modbus CRC Check failed! 9131!=00
I guess this comes from 'modbus_controller'
Threads: 1,578
because it's not a modbus protocol, it's a customsize private protocol.
Threads: 0
(10-06-2023, 10:40 PM)admin Wrote: because it's not a modbus protocol, it's a customsize private protocol.
yes, y do understand. But it confuses 'modbus_component' so that it can not be used together.
My installation would get an input from a kc868-HA over an kc868-Axx board (via Modbus) to an modbus relayboard.
Threads: 1,578
if you want KC868-HA to control KC868-A series relay board, you can let them connected together. they can work with each other directly. not need to use home assistant, that will be more stable.
Threads: 0
(10-07-2023, 10:17 AM)admin Wrote: if you want KC868-HA to control KC868-A series relay board, you can let them connected together. they can work with each other directly. not need to use home assistant, that will be more stable.
Code: - platform: kc868_component
name: kc868 addr1 key5 binary_sensor
addr: 1
key: 5
on_press:
then:
switch.toggle: kc868_addr1_channel2_switch
Code: [18:36:35][D][kc868.component:024]: uart bus receive 1:10:0:a:0:6:c:0:0:0:0:0:0:0:0:5:1:0:0:dd:7c
[18:36:35][D][binary_sensor:036]: 'kc868 addr1 key5 binary_sensor': Sending state ON
[18:36:35][D][switch:020]: 'kc868 addr1 channel1 switch' Toggling ON.
[18:36:35][D][kc868.component:125]: uart bus send 1:3:6:55:aa:0:0:0:1:f4:a8 <------------------------------------------------------ first kc868-Axx board sends 'kc868_component' command to kc868-HA board 1 to toggle output 1
[18:36:35][D][switch:055]: 'kc868 addr1 channel1 switch': Sending state ON
[18:36:35][D][binary_sensor:036]: 'kc868 addr1 key5 binary_sensor': Sending state OFF
If you send a [switch.toggle: kc868_addr1_channel2_switch] command to an kc868-HA board on the bus, it makes 'kc868_component' on another kc868-Axx board out of use!
addr: 1
key: 5
on_press:
then:
switch.toggle: light5
Both commands
- 1:10:0:a:0:6:c:0:0:0:0:0:0:0:0:5:1:0:0:dd:7c
- 1:3:6:55:aa:0:0:0:1:f4:a8
are received at +- the same time by the second kc868-Axx board and disrupts it. The second board will do nothing.
Code: [21:41:06][D][kc868.component:024]: uart bus receive 1:3:6:55:aa:0:0:0:3:75:69:1:10:0:a:0:6:c:0:0:0
[21:41:06][D][kc868.component:036]: crc check failed. ignore data
Threads: 1,578
wait for some days, we will release new plugin file for KC868-HA. i think make a video tour for you, how to use in home asssistant with a switch panel.
Threads: 0
10-09-2023, 07:28 AM
(This post was last modified: 10-09-2023, 08:02 AM by NicTheModder.)
(10-08-2023, 10:31 PM)admin Wrote: wait for some days, we will release new plugin file for KC868-HA. i think make a video tour for you, how to use in home asssistant with a switch panel.
Thank you verry much.
PS; I don't use home assistant for this project. Everything is configured in ESPHome and runs on your controllerboards only. Runs very stable. Hereby I use the components 'cover', 'monochromatic' and 'kc868_component'.
Everything is connected with the RS485-bus (modbus) and located on different locations. kc868-E16S and A16 are downstairs, A4S with 2DO (6 relays total and 6 x 0-10V dimmers connected) on first floor and 2 x kc868-HA in the building. In test-mounting I can push a kc868-HA button downstairs and activate a relay powered by a kc868-HA board in the bacement (low signal active).
For the moment the boards don't work together on the RS485-bus due to CRC-check problems when you send a command to an kc868-HA board (switch). Connected one at a time it runs smoothly.
I had to remove all modbus expansion boards (located in bacement and garage to open gate etc) because 'modbus_controller' don't work side-by-side with 'kc868_component'.
Homeassistant will be used for video-control and non crucial automations and integrations.
Greetings from Belgium
Nic
Threads: 1,578
sorry, i don't know understand deeply, can you take a video of your problem?
Threads: 0
10-10-2023, 07:22 AM
(This post was last modified: 10-11-2023, 09:04 AM by NicTheModder.)
(10-09-2023, 12:08 PM)admin Wrote: sorry, i don't know understand deeply, can you take a video of your problem?
I never made a video.
Do you have any suggestion for some video software? OBS Studio looks good.
This is a simplified examle;
| Use 3 boards;
| - 1 x kc868-HA named for simplicity HA
| - 2 x kc868-Axx named for simplicity A1 and A2
| Use 'kc868_controller' on A1 and A2
| Connect all boards on a rs485 line
When HA sends a message over the bus (switch 1 closed for example), both A1 and A2 will read this message.
When A1 sends that HA must close a switch, A2 will send an error message and A2 neglects all other messages send at that time.
This is because the structure of the message send by HA and 'kc868_controller' are different. 'kc868_controller' gives an error on its own messages when read on another board on the rs485-bus.
