  • 1 Vote(s) - 5 Average
"KCS" v2.2.2 firmware BIN file download
#61
How long does it take to flash the board?
I've been doing this for four hours now
https://youtu.be/xeVGEN2iVC4
this not begin download. only about 20 seconds will completed.
you should set correct COM port number.
Hello, I have a suggestion for a future firmware update. It would be great to have an option to "download" and "upload" the configuration settings you've made, so you can have a backup. For example, if you need to replicate the configuration on another similar board, or if for any reason the board needs to be replaced due to damage, it would be enough to have previously downloaded the configuration. That way, you could upload it to the new board without having to input all the parameters you had already configured one by one. Does that make sense? Thanks!
yes, you are right. maybe in furture can do that. But now if you want all setting and firmware GHOST to another new board, we already have made a video tour. the ESP32 have a backup tool. here is video: https://youtu.be/pUWbxX2K58A
1) installed USB driver
2) tried different cables (even branded Samsung)
3) what is in the video can last 2 and 8 hours without finishing.
does not flash
what to do?
https://youtu.be/6458e9m7uU4
[Image: 20240810-105406.jpg]
when you download firmware, MUST remove the RF receiver. Do you have removed it?
add whatsapp number: +86-15381188302 we can use ANYDESK remote control your computer have a look.
(12-07-2023, 01:31 AM)admin Wrote: Here is "KCS" firmware for KinCony KC868-A series (ESP32) board.
How to download and use, online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
v2.2.2 improment:
1. fixed bug can't show negative temperature with DS18B20
do you have KCS firmware for ADR module ?
yes, we have a version under testing. if you want , we can send to you.
(08-12-2024, 11:05 PM)admin Wrote: yes, we have a version under testing. if you want , we can send to you.
can you send me please a link, i wish to try it
here is ADR KCS firmware:
.zip   ADR_V1.0.4.zip (Size: 711.88 KB / Downloads: 523)
