before you config ymal file, please upload zmpt101b folder to home assistant disk:
unzip files, 3 files upload to disk folder as image.
.zip   zmpt101b.zip (Size: 1.83 KB / Downloads: 1,781)
.txt   KC868-M16v2-ESPHome.txt (Size: 9.55 KB / Downloads: 1,466)
  includes:
    - zmpt101b/ZMPT101B.h
    - zmpt101b/ZMPT101B.cpp
    - zmpt101b/zmpt101b_custom_sensor.h
    type: arduino
  encryption:
    key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "T: %.1f°C", id(temperature).state);
      it.printf(0, 20, id(roboto), "H: %.1f%%", id(humidity).state);
      it.printf(0, 40, id(roboto), "AC:%.1fV", id(voltage_2).state);
  - platform: custom
    lambda: |-
      auto my_sensor34 = new ZMPT101BSensor(34);
      auto my_sensor36 = new ZMPT101BSensor(36);
      auto my_sensor39 = new ZMPT101BSensor(39);
      App.register_component(my_sensor34);
      App.register_component(my_sensor36);
      App.register_component(my_sensor39);
      return {my_sensor34, my_sensor36, my_sensor39};
    sensors:
      - name: "m16--AI zmpt 34"
        unit_of_measurement: V
        accuracy_decimals: 1
        state_class: "measurement"
      - name: "m16--AI zmpt 36"
      - name: "m16--AI zmpt 39"
  - platform: sht3xd
    temperature:
      name: "sht Temperature"
    humidity:
      name: "sht Humidity"
    address: 0x44
    update_interval: 5s
  - platform: adc
    pin: 35
    update_interval: never
    attenuation: 11db
  # - platform: adc
  #  name: "m16--AI-1"
  #  pin: 36
  #  id: adc36
  #  update_interval: 60s
  #  attenuation: 11db
  # - platform: adc
  #  pin: 34
  #  name: "m16--AI-2"
  #  id: adc34
  #  attenuation: 11db
  # - platform: adc
  #  pin: 39
  #  name: "m16--AI-3"
  #  id: adc39
  #  attenuation: 11db
  - platform: cd74hc4067
    sensor: adc35
    sensor: adc35
    sensor: adc35
    sensor: adc35
    number: 4
    sensor: adc35
    number: 5
    sensor: adc35
    number: 6
    sensor: adc35
    number: 7
    sensor: adc35
    number: 8
    sensor: adc35
    number: 9
    sensor: adc35
    number: 10
    sensor: adc35
    number: 11
    sensor: adc35
    number: 12
    sensor: adc35
    number: 13
    sensor: adc35
    number: 14
    sensor: adc35
    number: 15
    sensor: adc35
  - platform: ct_clamp
    sensor: ai1
    name: "Measured Current-1"
    update_interval: 5s
    filters:
      - calibrate_linear:
          # Measured value of 0 maps to 0A
          - 0.0034 -> 0
          # Known load: 4.0A
          # Value shown in logs: 0.1333A
          - 0.31749 -> 8.95608
  - platform: template
    lambda: return id(Measured_Current_1).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: 'W'
  - platform: total_daily_energy
    name: "Total Daily Energy1"
    power_id: power1
    filters:
        - multiply: 0.001
    unit_of_measurement: kWh
    accuracy_decimals: 3
    icon: mdi:clock-alert
    device_class: energy
    sensor: ai2
    name: "Measured Current-2"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai3
    name: "Measured Current-3"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai4
    name: "Measured Current-4"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai5
    name: "Measured Current-5"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai6
    name: "Measured Current-6"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai7
    name: "Measured Current-7"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai8
    name: "Measured Current-8"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai9
    name: "Measured Current-9"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai10
    name: "Measured Current-10"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai11
    name: "Measured Current-11"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai12
    name: "Measured Current-12"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai13
    name: "Measured Current-13"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai14
    name: "Measured Current-14"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai15
    name: "Measured Current-15"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
    sensor: ai16
    name: "Measured Current-16"
    filters:
      - calibrate_linear:
          - 0 -> 0
          # Known load: 4.0A
time:
  - platform: sntp
Today I received my KC-868-M16-V2.1
I copied the files to the correct folder and created an yaml definition file for the board as described in this post.
During the compile of the yaml file //i get the errors below in the screenshot, any help is more than welcome, because I'm out of options.
take a photo of your component folder and file structure.
(02-28-2024, 09:47 PM)admin Wrote: take a photo of your component folder and file structure.
I guess you mean this?
Any news on this issue?
do you install your home assistant on a raspberry pi? i suggest you delete your ESPhome, re install it.
it's correct as your photo about fold and files.
My home assistant is running on an ODROID N2+ and I have tried to reinstall ESPhome, but without any luck.
the easiest way, you can install ESPHome on your computer or raspberry pi (not use ODROID N2 hardware), compile these code directly to test it. Because all our customers work well, so i think maybe some environment issue.
I bought 3 KC868-M16V2.1 boards from you, and I successfully connected them to Home Assistant.
I want to measure power and energy for three-phase 5 devices. How can I adjust the YAML template for this purpose?
Attached is a table showing how I want to connect the terminals for these devices.
Thanks
sure ,you can detect it. just chose correctly CT clamp sensors range.
