03-06-2024, 03:07 AM
Hi I wanted to add the AM2301 temperature and humidity sensor.
Is there an example of the code to add this type of sensor?
AM2301
03-06-2024, 04:30 AM
use by home assistant?
03-06-2024, 05:04 AM
Sorry should of said. Yes EspHome on home assistant.
Thanks
03-06-2024, 06:36 AM
you can see here: https://esphome.io/components/sensor/dht.html
just use DHT sensor code.
Great got it working, Thanks
I had to work out what pin to connect it to found that the S1- S4 GPIO14 1-Wire GPIO GPIO13 1-Wire GPIO GPIO32 1-Wire GPIO GPIO33 1-Wire GPIO
03-06-2024, 11:34 AM
ok, good.
