  • 1 Vote(s) - 5 Average
TUYA_ESP32_Adapter arduino source code 7.1 -support TCP connection
this 7.1 source code version, have added TCP connection with KinCony's relay board by WiFi. so now you can use RS232 or RS485 or WiFi connect to KinCony's KC868-H32BS, KC868-H32B, KC868-H32L, KC868-H32 relay controller.
just config relay board IP port for router by KC868-Adatper's AP (AP name is KC868-Tuya) webpage.
here is firmware BIN file, you can download to ESP32 directly by USB cable:
.zip   KinCony-Tuya-adapter.nodemcu-32s-7.1.zip (Size: 505.91 KB / Downloads: 912)
here is arduino source code:
.zip   KinCony-Tuya-adapter-source-code-7.1.zip (Size: 8.22 KB / Downloads: 912)
Supported products list:
source code:
/*KC868-Tuya adapter have 5 LEDs
* LED D1: when D1-OFF: ready to enable AP for config ESP32 wifi, AP name is KC868-Tuya      D1-ON: ESP32 connect to router successful
* LED D2: when D2-ON: ESP32 connect to relay board by TCP connection successfully
* LED D3: when D3-ON: KC868-Tuya adapter work in RS232 or RS485 mode
* LED D4: when D4 blink: ready to config Tuya wifi module for router SSID
* LED D6: KC868-Tuya adapter power LED
* Button S1:Tuya wifi module RESET key
* Button DL: ESP32 wifi RESET
* Button RST: ESP32 module RESET
* Jumper IO23: Short:by RS485   disconnect:by RS232
* @Copyright: KinCony IoT
#include <WiFi.h>
#include <TuyaWifi.h>
#include <SoftwareSerial.h>
#include "CRC16.h"
#include "CRC.h"
#include <WiFiManager.h>
#include "EEPROM.h"
#define TRIGGER_PIN 0   // reset wifi button
WiFiManager wm;
const char* ssid     = "xxx"; //your router's ssid
const char* password = "yyy"; //your router's password
WiFiServer server(80);
String header;
TuyaWifi my_device;
#define  RS485Address   0x01
#define  RS485Baud     9600
#define  RS232Baud     115200
#define  wifiReadDelay     3000
#define  RS232ReadDelay     3000
#define  RS485ReadDelay     3000
#define  wifiRelayDelay    1000
#define  RS232RelayDelay    500
#define  RS485RelayDelay    500
unsigned char pid[] = {"tsfqvoyi6pxqxq6o"};
//char c;
// Current time
// Previous time
int flag_read_di=0;
#define  ADDRESS_TARGET_FIRST  10
#define  ADDRESS_TARGET_IP     30
#define  ADDRESS_TARGET_PORT   60
#define  ADDRESS_TARGET_MODE   90
#define RS232_state   1
#define RS485_state   0
#define wifi_read_inputcom   0
#define wifi_read_relaycom   1
#define RS232_read_inputcom   0
#define RS232_read_relaycom   1
#define RS485_read_inputcom   0
#define RS485_read_relaycom   1
#define DISABLE   0
#define ENABLE   1
#define NOCONNECTED   0
#define CONNECTED   1
uint16_t  CRC16_Data = 0;
uint8_t  CRC16_Data_H = 0;
uint8_t  CRC16_Data_L = 0;
/* Current  status */
unsigned char wifi_connected = NOCONNECTED;
unsigned char led_state = 0;
//1=232 0=485
unsigned char uart_state = 1;
unsigned char wifi_state = ENABLE;
unsigned char wifi_stop = DISABLE;
unsigned char wifi_Check = ENABLE;
unsigned char RS232_Check = ENABLE;
unsigned char RS485_Check = ENABLE;
unsigned char wifi_read_com = 1;
//1= read RELAY  0 = read input
unsigned char RS232_read_com = 1;
unsigned char RS485_read_com = 1;
unsigned char switch_8_1_nowstate = 0;
unsigned char switch_16_9_nowstate = 0;
unsigned char switch_24_17_nowstate = 0;
unsigned char switch_32_25_nowstate = 0;
unsigned char switch_8_1_tarstate = 0;
unsigned char switch_16_9_tarstate = 0;
unsigned char switch_24_17_tarstate = 0;
unsigned char switch_32_25_tarstate = 0;
unsigned char pre_switch_8_1_tarstate = 0;
unsigned char pre_switch_16_9_tarstate = 0;
unsigned char pre_switch_24_17_tarstate = 0;
unsigned char pre_switch_32_25_tarstate = 0;
unsigned char pre_switch_8_1_nowstate = 0;
unsigned char pre_switch_16_9_nowstate = 0;
unsigned char pre_switch_24_17_nowstate = 0;
unsigned char pre_switch_32_25_nowstate = 0;
unsigned char switch_1_8_tarstate = 0;
unsigned char switch_9_16_tarstate = 0;
unsigned char switch_17_24_tarstate = 0;
unsigned char switch_25_32_tarstate = 0;
unsigned char switch_1_state = 0;
unsigned char switch_2_state = 0;
unsigned char switch_3_state = 0;
unsigned char switch_4_state = 0;
unsigned char switch_5_state = 0;
unsigned char switch_6_state = 0;
unsigned char input_1_state = 0;
unsigned char input_2_state = 0;
unsigned char input_3_state = 0;
unsigned char input_4_state = 0;
unsigned char input_5_state = 0;
unsigned char input_6_state = 0;
unsigned char switch_7_state = 0;
unsigned char switch_8_state = 0;
unsigned char switch_9_state = 0;
unsigned char switch_10_state = 0;
unsigned char switch_11_state = 0;
unsigned char switch_12_state = 0;
unsigned char switch_13_state = 0;
unsigned char switch_14_state = 0;
unsigned char switch_15_state = 0;
unsigned char switch_16_state = 0;
unsigned char switch_17_state = 0;
unsigned char switch_18_state = 0;
unsigned char switch_19_state = 0;
unsigned char switch_20_state = 0;
unsigned char switch_21_state = 0;
unsigned char switch_22_state = 0;
unsigned char switch_23_state = 0;
unsigned char switch_24_state = 0;
unsigned char switch_25_state = 0;
unsigned char switch_26_state = 0;
unsigned char switch_27_state = 0;
unsigned char switch_28_state = 0;
unsigned char switch_29_state = 0;
unsigned char switch_30_state = 0;
unsigned char switch_31_state = 0;
unsigned char switch_32_state = 0;
unsigned char switch_wifi_delay_state = 0;
unsigned char dpid_wifi_delay_switch = 0;
unsigned char en_wifi_delay_switch = 0;
//1= en delay   0= dis delay
unsigned char switch_232_delay_state = 0;
unsigned char dpid_232_delay_switch = 0;
unsigned char en_232_delay_switch = 0;
unsigned char switch_485_delay_state = 0;
unsigned char dpid_485_delay_switch = 0;
unsigned char en_485_delay_switch = 0;
unsigned char ini_state = 1;
unsigned char Rs485_Str[20] = {0};
int key_pin = 27;
/*  232(1) 485(0)  */
int sel_uart_pin = 32;
int index_pos = 0;
int index_begin = 0;
int index_end = 0;
#define BEGIN_DELAY   1
#define END_DELAY   0
/* Data point define */
#define DPID_SWITCH_1   1
#define DPID_SWITCH_2   2
#define DPID_SWITCH_3   3
#define DPID_SWITCH_4   4
#define DPID_SWITCH_5   5
#define DPID_SWITCH_6   6
#define DPID_INPUT_1   101
#define DPID_INPUT_2   102
#define DPID_INPUT_3   103
#define DPID_INPUT_4   104
#define DPID_INPUT_5   105
#define DPID_INPUT_6   106
#define DPID_SWITCH7   113
#define DPID_SWITCH8   114
#define DPID_SWITCH9   115
#define DPID_SWITCH10  116
#define DPID_SWITCH11  117
#define DPID_SWITCH12  118
#define DPID_SWITCH13  119
#define DPID_SWITCH14  120
#define DPID_SWITCH15  121
#define DPID_SWITCH16  122
#define DPID_SWITCH17  123
#define DPID_SWITCH18  124
#define DPID_SWITCH19  125
#define DPID_SWITCH20  126
#define DPID_SWITCH21  127
#define DPID_SWITCH22  128
#define DPID_SWITCH23  129
#define DPID_SWITCH24  130
#define DPID_SWITCH25  131
#define DPID_SWITCH26  132
#define DPID_SWITCH27  133
#define DPID_SWITCH28  134
#define DPID_SWITCH29  135
#define DPID_SWITCH30  136
#define DPID_SWITCH31  137
#define DPID_SWITCH32  138
#define LED_TUYA_WiFi  26
#define LED_User1  32
#define LED_ESP_WiFi  33
#define LED_User2  25
*                                     dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
  {DPID_SWITCH_1, DP_TYPE_BOOL},{DPID_SWITCH_2, DP_TYPE_BOOL},{DPID_SWITCH_3, DP_TYPE_BOOL},{DPID_SWITCH_4, DP_TYPE_BOOL},{DPID_SWITCH_5, DP_TYPE_BOOL},{DPID_SWITCH_6, DP_TYPE_BOOL},
  {DPID_INPUT_1, DP_TYPE_BOOL},{DPID_INPUT_2, DP_TYPE_BOOL},{DPID_INPUT_3, DP_TYPE_BOOL},{DPID_INPUT_4, DP_TYPE_BOOL},{DPID_INPUT_5, DP_TYPE_BOOL},{DPID_INPUT_6, DP_TYPE_BOOL},
  {DPID_SWITCH7, DP_TYPE_BOOL},{DPID_SWITCH8, DP_TYPE_BOOL},{DPID_SWITCH9, DP_TYPE_BOOL},{DPID_SWITCH10, DP_TYPE_BOOL},{DPID_SWITCH11, DP_TYPE_BOOL},{DPID_SWITCH12, DP_TYPE_BOOL},
  {DPID_SWITCH13, DP_TYPE_BOOL},{DPID_SWITCH14, DP_TYPE_BOOL},{DPID_SWITCH15, DP_TYPE_BOOL},{DPID_SWITCH16, DP_TYPE_BOOL},{DPID_SWITCH17, DP_TYPE_BOOL},{DPID_SWITCH18, DP_TYPE_BOOL},
  {DPID_SWITCH19, DP_TYPE_BOOL},{DPID_SWITCH20, DP_TYPE_BOOL},{DPID_SWITCH21, DP_TYPE_BOOL},{DPID_SWITCH22, DP_TYPE_BOOL},{DPID_SWITCH23, DP_TYPE_BOOL},{DPID_SWITCH24, DP_TYPE_BOOL},
  {DPID_SWITCH25, DP_TYPE_BOOL},{DPID_SWITCH26, DP_TYPE_BOOL},{DPID_SWITCH27, DP_TYPE_BOOL},{DPID_SWITCH28, DP_TYPE_BOOL},{DPID_SWITCH29, DP_TYPE_BOOL},{DPID_SWITCH30, DP_TYPE_BOOL},
{DPID_SWITCH31, DP_TYPE_BOOL},{DPID_SWITCH32, DP_TYPE_BOOL},
/* last time */
unsigned long last_time = 0;
unsigned long RS485_last_time = 0;
unsigned long RS232_last_time = 0;
unsigned long wifi_last_time = 0;
unsigned long wifi_delay_last_time = 0;
unsigned long wifi_relay_last_time = 0;
unsigned long RS232_delay_last_time = 0;
unsigned long RS232_relay_last_time = 0;
unsigned long RS485_delay_last_time = 0;
unsigned long RS485_relay_last_time = 0;
String indata="";
String val="";
String outdata="";
String relay_outdata="";
String subval="";
int numsubval[6]={0};
String currentLine="";
String  TARGET_FIRST="";
String  TARGET_IP="";
String  TARGET_PORT="";
String  TARGET_MODE="";
String  NEW_TARGET_IP="";
String  NEW_TARGET_PORT="";
String  NEW_TARGET_MODE="";
int address = 0;
String relay32state = "off";// state of relay32
WiFiClient client  ;   // clients
void setup()
  ini_state = 1;
  pinMode(LED_TUYA_WiFi, OUTPUT);
  digitalWrite(LED_TUYA_WiFi, LOW);
  pinMode(LED_ESP_WiFi, OUTPUT);
  digitalWrite(LED_ESP_WiFi, LOW);
  pinMode(LED_User1, OUTPUT);
  digitalWrite(LED_User1, LOW);
  pinMode(LED_User2, OUTPUT);
  digitalWrite(LED_User2, LOW);
  // wifi reset button
  pinMode(TRIGGER_PIN, INPUT_PULLUP);
  //Initialize networking key
  //Initialize sel key
  pinMode(sel_uart_pin, INPUT_PULLUP);
  //  0 SEL 485    1 SEL 232
  uart_state = RS485_state;
  if (digitalRead(sel_uart_pin) == LOW) {
    delay(80);
  uart_state = RS232_state;
  if(uart_state == RS232_state)
    Serial2.begin(RS232Baud,SERIAL_8N1,16,17);
  else
    Serial2.begin(RS485Baud,SERIAL_8N1,16,17);
// Serial with tuyawifi
Serial.begin(9600,SERIAL_8N1,14,13);
    // Serial with debug
Serial1.begin(9600,SERIAL_8N1,3,1);
Serial1.println("\nTesting EEPROM Library\n");
  if (!EEPROM.begin(1000)) {
    Serial1.println("Failed to initialise EEPROM");
    //Serial2.println("Restarting...");
    delay(1000);
    //ESP.restart();
  my_device.init(pid, mcu_ver);
  my_device.set_dp_cmd_total(dp_array, 1);
  address = ADDRESS_TARGET_FIRST;
  TARGET_FIRST = EEPROM.readString(address);
  address = ADDRESS_TARGET_IP;
  TARGET_IP = EEPROM.readString(address);
  address = ADDRESS_TARGET_PORT;
  TARGET_PORT = EEPROM.readString(address);
  address = ADDRESS_TARGET_MODE;
  TARGET_MODE = EEPROM.readString(address);
  //default
  if (TARGET_FIRST != "123456")
     TARGET_IP="192.168.1.200";
     TARGET_PORT="4196";
     TARGET_MODE="wifi";
// Connect to Wi-Fi network with SSID and password
  WiFi.mode(WIFI_STA);
//close wifi sleep
  WiFi.setSleep(false);
  // Define a text box, 50 characters maximum
  WiFiManagerParameter custom_text_box("my_text", "Enter Relay Board IP", TARGET_IP.c_str(), 50);
  // Add custom parameter
  wm.addParameter(&custom_text_box);
  WiFiManagerParameter custom_text_box2("my_text2", "Enter Relay Board Port", TARGET_PORT.c_str(), 50);
  wm.addParameter(&custom_text_box2);
  WiFiManagerParameter custom_text_box3("my_text3", "Enter wifi or 232 or 485", TARGET_MODE.c_str(), 50);
  wm.addParameter(&custom_text_box3);
     bool res;
       res = wm.autoConnect("KC868-Tuya"); // anonymous ap
    if(!res) {
        Serial1.println("Failed to connect");
        //ESP.restart();
    else {
        Serial1.println("connected...yeey :)");
    delay(500);
    Serial1.print(".");
  Serial1.println("");
  Serial1.println("WiFi connected.");
  Serial1.println("Local IP address: ");
  Serial1.println(WiFi.localIP());
    // Print custom text box value to serial monitor
  NEW_TARGET_IP = custom_text_box.getValue();
  NEW_TARGET_PORT = custom_text_box2.getValue();
  NEW_TARGET_MODE = custom_text_box3.getValue();
  if(NEW_TARGET_IP != TARGET_IP)
     TARGET_IP = NEW_TARGET_IP;
     EEPROM.writeString(address, TARGET_IP);
     TARGET_FIRST = "123456";
     EEPROM.writeString(address, TARGET_FIRST);
     EEPROM.commit();
  if(NEW_TARGET_PORT != TARGET_PORT)
     TARGET_PORT = NEW_TARGET_PORT;
     EEPROM.writeString(address, TARGET_PORT);
     EEPROM.commit();
  if(NEW_TARGET_MODE != TARGET_MODE)
     TARGET_MODE = NEW_TARGET_MODE;
     EEPROM.writeString(address, TARGET_MODE);
     EEPROM.commit();
  Serial1.print("target IP: ");
  Serial1.println(TARGET_IP);
  Serial1.print("target port: ");
  Serial1.println(TARGET_PORT);
  Serial1.print("target mode: ");
  Serial1.println(TARGET_MODE);
  //server.begin(); ???????????????????????????????
digitalWrite(LED_User1, HIGH);
  last_time = millis();
void loop()
if((TARGET_MODE=="wifi")||(TARGET_MODE=="WIFI"))
const char* host = TARGET_IP.c_str();
int httpPort = TARGET_PORT.toInt();
if (client.connect(host, httpPort)) {
       digitalWrite(LED_ESP_WiFi, HIGH);
    while (client.connected() || client.available())
     // wifi_connected = CONNECTED;
      if(client.available() )
      String line = client.readStringUntil('\n');
      Serial1.print("line=");
      Serial1.println(line);
      //if(line.length()<50)
      // indata = line;
      // //Serial1.print("indata=");
      // Serial1.println(indata);
      //client.write(line.c_str());
       if(line.indexOf("RELAY-SET_ALL-255") >= 0)
       index_begin = line.indexOf("RELAY-SET_ALL-255");
       index_end = line.indexOf("OK", index_begin);
       index_end = index_end + 2;
       indata = line.substring(index_begin,index_end);
       else if(line.indexOf("RELAY-GET_INPUT-255") >= 0)
       index_begin = line.indexOf("RELAY-GET_INPUT-255");
       else if(line.indexOf("RELAY-STATE-255") >= 0)
       index_begin = line.indexOf("RELAY-STATE-255");
       else if(line.indexOf("RELAY-ALARM") >= 0)
       index_begin = line.indexOf("RELAY-ALARM");
       else if(line.indexOf("RELAY-DIARM") >= 0)
       index_begin = line.indexOf("RELAY-DIARM");
  /////////////wifi mode begin
  if((en_wifi_delay_switch == BEGIN_DELAY)&&(wifi_state == ENABLE))
    if((millis()-wifi_delay_last_time)>=20)
      my_device.mcu_dp_update(dpid_wifi_delay_switch, switch_wifi_delay_state, 1);
      en_wifi_delay_switch = END_DELAY;
    if((indata.length()>0)&&(((uart_state == RS232_state)&&(wifi_state == DISABLE))||(wifi_state == ENABLE)))
     val=indata;   //
  //----------INPUT ALARM--------
      if(val=="RELAY-ALARM-1,OK")
        input_1_state = 1;
        my_device.mcu_dp_update(DPID_INPUT_1, input_1_state, 1);
     else if(val=="RELAY-DIARM-1,OK")
        input_1_state = 0;
     else if(val=="RELAY-ALARM-2,OK")
        input_2_state = 1;
        my_device.mcu_dp_update(DPID_INPUT_2, input_2_state, 1);
     else if(val=="RELAY-DIARM-2,OK")
        input_2_state = 0;
     else if(val=="RELAY-ALARM-3,OK")
        input_3_state = 1;
        my_device.mcu_dp_update(DPID_INPUT_3, input_3_state, 1);
     else if(val=="RELAY-DIARM-3,OK")
        input_3_state = 0;
     else if(val=="RELAY-ALARM-4,OK")
        input_4_state = 1;
        my_device.mcu_dp_update(DPID_INPUT_4, input_4_state, 1);
     else if(val=="RELAY-DIARM-4,OK")
        input_4_state = 0;
     else if(val=="RELAY-ALARM-5,OK")
        input_5_state = 1;
        my_device.mcu_dp_update(DPID_INPUT_5, input_5_state, 1);
     else if(val=="RELAY-DIARM-5,OK")
        input_5_state = 0;
     else if(val=="RELAY-ALARM-6,OK")
        input_6_state = 1;
        my_device.mcu_dp_update(DPID_INPUT_6, input_6_state, 1);
     else if(val=="RELAY-DIARM-6,OK")
        input_6_state = 0;
     //----INPUT READ BACK
     else if((val.substring(0,19)=="RELAY-GET_INPUT-255"))
       //wifi_stop = DISABLE;
       subval =  val.substring(20);
       int j=0;
       int m=subval.length();
       for(int i=0; i<m; i++)
       if(subval[i]==',')
         j++;
        else
          numsubval[j]=numsubval[j]*10+(subval[i]-'0');
        input_6_state = (numsubval[0]&0x20)?0:1;
        input_5_state = (numsubval[0]&0x10)?0:1;
        input_4_state = (numsubval[0]&0x08)?0:1;
        input_3_state = (numsubval[0]&0x04)?0:1;
        input_2_state = (numsubval[0]&0x02)?0:1;
        input_1_state = (numsubval[0]&0x01)?0:1;
        numsubval[0]=0;
        numsubval[1]=0;
        numsubval[2]=0;
        numsubval[3]=0;
        numsubval[4]=0;
        numsubval[5]=0;
     //----ALL-RELAY-STATE  READ BACK
     else if((val.substring(0,15)=="RELAY-STATE-255"))
       subval =  val.substring(16);
       int j=0;
       if(subval[i]==',')
         j++;
        else
        switch_32_25_nowstate = numsubval[0];
        switch_32_state = (switch_32_25_nowstate&0x80)?1:0;
        switch_31_state = (switch_32_25_nowstate&0x40)?1:0;
        switch_30_state = (switch_32_25_nowstate&0x20)?1:0;
        switch_29_state = (switch_32_25_nowstate&0x10)?1:0;
        switch_28_state = (switch_32_25_nowstate&0x08)?1:0;
        switch_27_state = (switch_32_25_nowstate&0x04)?1:0;
        switch_26_state = (switch_32_25_nowstate&0x02)?1:0;
        switch_25_state = (switch_32_25_nowstate&0x01)?1:0;
        switch_24_17_nowstate = numsubval[1];
        switch_24_state = (switch_24_17_nowstate&0x80)?1:0;
        switch_23_state = (switch_24_17_nowstate&0x40)?1:0;
        switch_22_state = (switch_24_17_nowstate&0x20)?1:0;
        switch_21_state = (switch_24_17_nowstate&0x10)?1:0;
        switch_20_state = (switch_24_17_nowstate&0x08)?1:0;
        switch_19_state = (switch_24_17_nowstate&0x04)?1:0;
        switch_18_state = (switch_24_17_nowstate&0x02)?1:0;
        switch_17_state = (switch_24_17_nowstate&0x01)?1:0;
        switch_16_9_nowstate = numsubval[2];
        switch_16_state = (switch_16_9_nowstate&0x80)?1:0;
        switch_15_state = (switch_16_9_nowstate&0x40)?1:0;
        switch_14_state = (switch_16_9_nowstate&0x20)?1:0;
         switch_13_state = (switch_16_9_nowstate&0x10)?1:0;
        switch_12_state = (switch_16_9_nowstate&0x08)?1:0;
        switch_11_state = (switch_16_9_nowstate&0x04)?1:0;
        switch_10_state = (switch_16_9_nowstate&0x02)?1:0;
        switch_9_state =  (switch_16_9_nowstate&0x01)?1:0;
        switch_8_1_nowstate = numsubval[3];
        switch_8_state = (switch_8_1_nowstate&0x80)?1:0;
        switch_7_state = (switch_8_1_nowstate&0x40)?1:0;
        switch_6_state = (switch_8_1_nowstate&0x20)?1:0;
        switch_5_state = (switch_8_1_nowstate&0x10)?1:0;
        switch_4_state = (switch_8_1_nowstate&0x08)?1:0;
        switch_3_state = (switch_8_1_nowstate&0x04)?1:0;
        switch_2_state = (switch_8_1_nowstate&0x02)?1:0;
        switch_1_state = (switch_8_1_nowstate&0x01)?1:0;
        if(ini_state==1)
         ini_state=0 ;
         switch_8_1_tarstate = switch_8_1_nowstate;
         switch_16_9_tarstate = switch_16_9_nowstate;
         switch_24_17_tarstate = switch_24_17_nowstate;
         switch_32_25_tarstate = switch_32_25_nowstate;
        numsubval[0]=0;
        numsubval[1]=0;
        numsubval[2]=0;
        numsubval[3]=0;
        numsubval[4]=0;
        numsubval[5]=0;
        my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH7, switch_7_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH8, switch_8_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH9, switch_9_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH10, switch_10_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH11, switch_11_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH12, switch_12_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH13, switch_13_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH14, switch_14_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH15, switch_15_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH16, switch_16_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH17, switch_17_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH18, switch_18_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH19, switch_19_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH20, switch_20_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH21, switch_21_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH22, switch_22_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH23, switch_23_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH24, switch_24_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH25, switch_25_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH26, switch_26_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH27, switch_27_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH28, switch_28_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH29, switch_29_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH30, switch_30_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH31, switch_31_state, 1);
        my_device.mcu_dp_update(DPID_SWITCH32, switch_32_state, 1);
     //----RELAY SET READ BACK
     else if((val.substring(0,17)=="RELAY-SET_ALL-255"))
       subval =  val.substring(18);
       int j=0;
       if(subval[i]==',')
         j++;
        else
        numsubval[0]=0;
        numsubval[1]=0;
        numsubval[2]=0;
        numsubval[3]=0;
        numsubval[4]=0;
        numsubval[5]=0;
           wifi_Check = ENABLE ;
     // wifi_last_time = millis();
    indata="";   //clear indata
   my_device.uart_service();
  //Enter the connection network mode when Pin27 is pressed.
    delay(80);
      if (led_state == LOW) {
        led_state = HIGH;
      } else {
        led_state = LOW;
      digitalWrite(LED_TUYA_WiFi, led_state);
    if(wifi_state == ENABLE)
    if ((pre_switch_8_1_nowstate != switch_8_1_nowstate) || (pre_switch_16_9_nowstate != switch_16_9_nowstate) || (pre_switch_24_17_nowstate != switch_24_17_nowstate) || (pre_switch_32_25_nowstate != switch_32_25_nowstate))
      pre_switch_8_1_nowstate = switch_8_1_nowstate;
      pre_switch_16_9_nowstate = switch_16_9_nowstate;
      pre_switch_24_17_nowstate = switch_24_17_nowstate;
      pre_switch_32_25_nowstate = switch_32_25_nowstate;
      switch_8_1_tarstate = switch_8_1_nowstate ;
      switch_16_9_tarstate = switch_16_9_nowstate ;
      switch_24_17_tarstate = switch_24_17_nowstate ;
      switch_32_25_tarstate = switch_32_25_nowstate ;
    else if ((switch_8_1_tarstate != switch_8_1_nowstate) || (switch_16_9_tarstate != switch_16_9_nowstate) || (switch_24_17_tarstate != switch_24_17_nowstate) || (switch_32_25_tarstate != switch_32_25_nowstate))
    if (millis()- wifi_relay_last_time >= wifiRelayDelay)
      wifi_Check = DISABLE ;
      wifi_relay_last_time = millis();
      if((switch_8_1_tarstate == pre_switch_8_1_tarstate) && (switch_16_9_tarstate == pre_switch_16_9_tarstate) && (switch_24_17_tarstate == pre_switch_24_17_tarstate) && (switch_32_25_tarstate == pre_switch_32_25_tarstate))
      relay_outdata = "";
      relay_outdata = relay_outdata + "RELAY-SET_ALL-255," + switch_32_25_tarstate + "," + switch_24_17_tarstate + "," + switch_16_9_tarstate + "," + switch_8_1_tarstate ;
      client.print(relay_outdata);
      Serial1.println(relay_outdata);
      switch_8_1_nowstate = switch_8_1_tarstate ;
      switch_16_9_nowstate = switch_16_9_tarstate ;
      switch_24_17_nowstate = switch_24_17_tarstate ;
      switch_32_25_nowstate = switch_32_25_tarstate ;
      else
      pre_switch_8_1_tarstate = switch_8_1_tarstate ;
      pre_switch_16_9_tarstate = switch_16_9_tarstate ;
      pre_switch_24_17_tarstate = switch_24_17_tarstate ;
      pre_switch_32_25_tarstate = switch_32_25_tarstate ;
    if (millis()- wifi_last_time >= wifiReadDelay)
     if(wifi_read_com == wifi_read_relaycom)
     outdata = "RELAY-STATE-255";
     client.print(outdata);
     wifi_stop = ENABLE;
     wifi_read_com = wifi_read_inputcom;
     else if(wifi_read_com == wifi_read_inputcom)
     outdata = "RELAY-GET_INPUT-255";
     wifi_stop = ENABLE;
     wifi_read_com = wifi_read_relaycom;
    //wifi mode end
       client.stop();
else
       wifi_state = DISABLE;
       client.stop();
     delay(5000);
else
   digitalWrite(LED_User2, HIGH);
  //no wifi mode begin
  if((uart_state == RS232_state)&&(wifi_state == DISABLE))
  while(Serial2.available()>0)
    indata+=char(Serial2.read());  //read KBOX via 232
    delay(2);
    if(Serial2.available()<=0)
        //Serial2.print(indata);
  else if((uart_state == RS485_state)&&(wifi_state == DISABLE))
    indata+=char(Serial2.read());   //read KBOX via 485
    delay(2);
  if((en_232_delay_switch == BEGIN_DELAY)&&(uart_state == RS232_state)&&(wifi_state == DISABLE))
    if((millis()-RS232_delay_last_time)>=20)
      my_device.mcu_dp_update(dpid_232_delay_switch, switch_232_delay_state, 1);
      en_232_delay_switch = END_DELAY;
    if((en_485_delay_switch == BEGIN_DELAY)&&(uart_state == RS485_state)&&(wifi_state == DISABLE))
    if((millis()-RS485_delay_last_time)>=20)
      my_device.mcu_dp_update(dpid_485_delay_switch, switch_485_delay_state, 1);
      en_485_delay_switch = END_DELAY;
    if((indata.length()>0)&&((uart_state == RS232_state)&&(wifi_state == DISABLE)))
     val=indata;   //
        input_1_state = 1;
        input_1_state = 0;
        input_2_state = 1;
        input_2_state = 0;
        input_3_state = 1;
        input_3_state = 0;
        input_4_state = 1;
        input_4_state = 0;
        input_5_state = 1;
        input_5_state = 0;
        input_6_state = 1;
        input_6_state = 0;
       int j=0;
       if(subval[i]==',')
         j++;
        else
        numsubval[0]=0;
        numsubval[1]=0;
        numsubval[2]=0;
        numsubval[3]=0;
        numsubval[4]=0;
        numsubval[5]=0;
       int j=0;
       if(subval[i]==',')
         j++;
        else
        if(ini_state==1)
         ini_state=0 ;
        numsubval[0]=0;
        numsubval[1]=0;
        numsubval[2]=0;
        numsubval[3]=0;
        numsubval[4]=0;
        numsubval[5]=0;
       int j=0;
       if(subval[i]==',')
         j++;
        else
        numsubval[0]=0;
        numsubval[1]=0;
        numsubval[2]=0;
        numsubval[3]=0;
        numsubval[4]=0;
        numsubval[5]=0;
           RS232_Check = ENABLE ;
    if((indata.length()>0)&&(uart_state == RS485_state)&&(wifi_state == DISABLE))
     val=indata;   //
  //----------INPUT READ BACK----------
     if((val[0]==RS485Address)&&(val[1]==0x02)&&(val[2]==0x01))
        input_1_state=(val[3]&0x01)?1:0 ;
        input_2_state=(val[3]&0x02)?1:0 ;
        input_3_state=(val[3]&0x04)?1:0 ;
        input_4_state=(val[3]&0x08)?1:0 ;
        input_5_state=(val[3]&0x10)?1:0 ;
        input_6_state=(val[3]&0x20)?1:0 ;
    else if((val[0]==RS485Address)&&(val[1]==0x01)&&(val[2]==0x04))
        switch_32_25_nowstate = val[3];
        switch_24_17_nowstate = val[4];
        switch_16_9_nowstate = val[5];
        switch_8_1_nowstate = val[6];
        if(ini_state==1)
         ini_state=0 ;
     else if((val[0]==RS485Address)&&(val[1]==0x0F)&&(val[2]==0x00)&&(val[3]==0x00)&&(val[4]==0x00)&&(val[5]==0x20))
        //switch_32_25_nowstate = ;
        //switch_24_17_nowstate = ;
        //switch_16_9_nowstate = ;
        //switch_8_1_nowstate = ;
        RS485_Check = ENABLE ;
    delay(80);
        led_state = HIGH;
      } else {
        led_state = LOW;
    if (millis()- RS232_relay_last_time >= RS232RelayDelay)
      RS232_Check = DISABLE ;
      RS232_relay_last_time = millis();
      relay_outdata = "";
      Serial2.print(relay_outdata);
      else
    if (millis()- RS485_relay_last_time >= RS485RelayDelay)
      RS485_Check = DISABLE ;
      RS485_relay_last_time = millis();
       Rs485_Str[0] = RS485Address;
       Rs485_Str[1] = 0x0F;
       Rs485_Str[2] = 0x00;
       Rs485_Str[3] = 0x00;
       Rs485_Str[4] = 0x00;
       Rs485_Str[5] = 0x20;
       Rs485_Str[6] = 0x04;
       Rs485_Str[7] = switch_8_1_tarstate;
       Rs485_Str[8] = switch_16_9_tarstate;
       Rs485_Str[9] = switch_24_17_tarstate;
       Rs485_Str[10] =  switch_32_25_tarstate;
       outdata = "1234567890123";
       outdata[0] = Rs485_Str[0];
       outdata[1] = Rs485_Str[1];
       outdata[2] = Rs485_Str[2];
       outdata[3] = Rs485_Str[3];
       outdata[4] = Rs485_Str[4];
       outdata[5] = Rs485_Str[5];
       outdata[6] = Rs485_Str[6];
       outdata[7] = Rs485_Str[7];
       outdata[8] = Rs485_Str[8];
       outdata[9] = Rs485_Str[9];
       outdata[10] = Rs485_Str[10];
       CRC16_Data = (crc16((uint8_t *) Rs485_Str, 11, 0x8005, 0xFFFF, 0, true, true));
       CRC16_Data_H = CRC16_Data/256;
       CRC16_Data_L = CRC16_Data%256;
       outdata[11] = CRC16_Data_L;
       outdata[12] = CRC16_Data_H;
       Serial2.print(outdata);
       switch_32_25_nowstate = switch_32_25_tarstate;
       switch_24_17_nowstate = switch_24_17_tarstate;
       switch_16_9_nowstate = switch_16_9_tarstate;
       switch_8_1_nowstate = switch_8_1_tarstate;
      else
  if((uart_state == RS232_state) && (RS232_Check == ENABLE)&&(wifi_state == DISABLE))
    if (millis()- RS232_last_time >= RS232ReadDelay)
      RS232_last_time = millis();
     if(RS232_read_com == RS232_read_relaycom)
     RS232_read_com = RS232_read_inputcom;
     else if(RS232_read_com == RS232_read_inputcom)
     RS232_read_com = RS232_read_relaycom;
  if((uart_state == RS485_state) && (RS485_Check == ENABLE)&&(wifi_state == DISABLE))
    if (millis()- RS485_last_time >= RS485ReadDelay)
      RS485_last_time = millis();
     if(RS485_read_com == RS485_read_relaycom)
       //read all realay
       Rs485_Str[1] = 0x01;
       outdata = "12345678";
       CRC16_Data = (crc16((uint8_t *) Rs485_Str, 6, 0x8005, 0xFFFF, 0, true, true));
       outdata[6] = CRC16_Data_L;
       outdata[7] = CRC16_Data_H;
       RS485_read_com = RS485_read_inputcom;
     else if(RS485_read_com == RS485_read_inputcom)
       //read all inputs
       Rs485_Str[1] = 0x02;
       Rs485_Str[5] = 0x08;
     RS485_read_com = RS485_read_relaycom;
  delay(10);
    // return;
* @param {unsigned char} dpid
* @return {unsigned char}
  if((uart_state == RS232_state) || (uart_state == RS485_state))
  switch(dpid) {
    case DPID_SWITCH_1:
      switch_1_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_1_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(1-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(1-1)));
    break;
    case DPID_SWITCH_2:
      switch_2_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_2_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(2-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(2-1)));
      //Status changes should be reported.
    break;
    case DPID_SWITCH_3:
      switch_3_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_3_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(3-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(3-1)));
    break;
    case DPID_SWITCH_4:
      switch_4_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_4_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(4-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(4-1)));
    break;
    case DPID_SWITCH_5:
      switch_5_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_5_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(5-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(5-1)));
    break;
    case DPID_SWITCH_6:
      switch_6_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_6_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(6-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(6-1)));
    break;
    case DPID_SWITCH7:
      switch_7_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_7_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(7-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(7-1)));
    break;
    case DPID_SWITCH8:
      switch_8_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_8_state) {
        //Turn on
       switch_8_1_tarstate = switch_8_1_tarstate | (1<<(8-1));
      } else {
        //Turn off
       switch_8_1_tarstate = switch_8_1_tarstate & (~(1<<(8-1)));
    break;
    case DPID_SWITCH9:
      switch_9_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_9_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(1-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(1-1)));
    break;
    case DPID_SWITCH10:
      switch_10_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_10_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(2-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(2-1)));
    break;
    case DPID_SWITCH11:
      switch_11_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_11_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(3-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(3-1)));
    break;
    case DPID_SWITCH12:
      switch_12_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_12_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(4-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(4-1)));
    break;
    case DPID_SWITCH13:
      switch_13_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_13_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(5-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(5-1)));
    break;
    case DPID_SWITCH14:
      switch_14_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_14_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(6-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(6-1)));
    break;
    case DPID_SWITCH15:
      switch_15_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_15_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(7-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(7-1)));
    break;
    case DPID_SWITCH16:
      switch_16_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_16_state) {
        //Turn on
       switch_16_9_tarstate = switch_16_9_tarstate | (1<<(8-1));
      } else {
        //Turn off
       switch_16_9_tarstate = switch_16_9_tarstate & (~(1<<(8-1)));
    break;
    case DPID_SWITCH17:
      switch_17_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_17_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(1-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(1-1)));
    break;
    case DPID_SWITCH18:
      switch_18_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_18_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(2-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(2-1)));
    break;
    case DPID_SWITCH19:
      switch_19_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_19_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(3-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(3-1)));
    break;
    case DPID_SWITCH20:
      switch_20_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_20_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(4-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(4-1)));
    break;
    case DPID_SWITCH21:
      switch_21_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_21_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(5-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(5-1)));
    break;
    case DPID_SWITCH22:
      switch_22_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_22_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(6-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(6-1)));
    break;
    case DPID_SWITCH23:
      switch_23_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_23_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(7-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(7-1)));
    break;
    case DPID_SWITCH24:
      switch_24_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_24_state) {
        //Turn on
       switch_24_17_tarstate = switch_24_17_tarstate | (1<<(8-1));
      } else {
        //Turn off
       switch_24_17_tarstate = switch_24_17_tarstate & (~(1<<(8-1)));
    break;
    case DPID_SWITCH25:
      switch_25_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_25_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(1-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(1-1)));
    break;
    case DPID_SWITCH26:
      switch_26_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_26_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(2-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(2-1)));
    break;
    case DPID_SWITCH27:
      switch_27_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_27_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(3-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(3-1)));
    break;
    case DPID_SWITCH28:
      switch_28_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_28_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(4-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(4-1)));
    break;
    case DPID_SWITCH29:
      switch_29_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_29_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(5-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(5-1)));
    break;
    case DPID_SWITCH30:
      switch_30_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_30_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(6-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(6-1)));
    break;
    case DPID_SWITCH31:
      switch_31_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_31_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(7-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(7-1)));
    break;
    case DPID_SWITCH32:
      switch_32_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      if (switch_32_state) {
        //Turn on
       switch_32_25_tarstate = switch_32_25_tarstate | (1<<(8-1));
      } else {
        //Turn off
       switch_32_25_tarstate = switch_32_25_tarstate & (~(1<<(8-1)));
    break;
    default:break;
  return TY_SUCCESS;
* @param {*}
* @return {*}
void dp_update_all(void)
LED-D1: OFF: ready for config ESP32 wifi. ON: config wifi completed
LED-D2: ON: connect to relay controller by wifi network successfully
LED-D3: ON: work on RS232/RS485 mode
LED-D4: indicator for Tuya module: Blink: ready to config wifi
LED-D6: Power LED
LEDs on PCB:
Button:
RST: reset for ESP32
D.L.: factory reset (clear all data)
here is new BIN file can download to ESP32:
.zip   flash_download_tool_3.9.3.zip (Size: 29.57 MB / Downloads: 1,013)
config ESP32 wifi firstly, then you can set relay controller's IP and Port in ESP32 webpage. make sure your relay controller work mode= TCP Server. if you don't want to use by TCP connection, you can set to RS232/RS485 mode, then you can begin config Tuya wifi.
all firmware files download:
.zip   boot_app0.zip (Size: 200 bytes / Downloads: 498)
.zip   bootloader_dio_40m.zip (Size: 11.35 KB / Downloads: 494)
.zip   KinCony-Tuya-adapter.nodemcu-32s-7.1.zip (Size: 505.91 KB / Downloads: 541)
.zip   default.zip (Size: 266 bytes / Downloads: 512)
I want to ask about the Arduino source code :
1. Where i have to install this file? Do i need Arduino r3 board for it? Or ghe Tuya adapter v1 support this file?
I don’t know how it works, so i need i at least to know how this Arduino works!!
use by ESP32 chip, install tuya arduino library firstly.
(05-14-2024, 07:50 AM)admin Wrote: use by ESP32 chip, install tuya arduino library firstly
1.is there a video tour explains the steps how to do it?
2. what i will get from arduinosource code after installing it in tuya adapter esp chip?
1. check video tour on our YouTube channel.
2. arduino source code download link already in this thread.
(05-14-2024, 07:50 AM)admin Wrote: use by ESP32 chip, install tuya arduino library firstly.
after installing tuya arduino library, what i have to do?
what is this arduino code" https://www.kincony.com/forum/images/att...es/zip.png" gives me when installing it in the esp chip? does it have a new features or what?
here is video tour: https://youtu.be/z67pRMLb4Rc
