I am unable to merge the yaml files for the ESP32-S3 Core Board and the I2C IO Expander inoput board DI8.
I merged them, and I think the SCL and SDA lines are set up correctly (GPIO38 and GPIO39). When compiling, I get an error in ESP-HOME every time.
I get the error below:
Reading CMake configuration...
Dependency Graph
|-- noise-c @ 0.1.4
|-- ArduinoJson @ 6.18.5
Linking .pioenvs/controller_avs412/firmware.elf
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x70): undefined reference to `vtable for esphome::i2c::IDFI2CBus'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x74): undefined reference to `vtable for esphome::i2c::IDFI2CBus'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x94): undefined reference to `vtable for esphome::pcf8574::PCF8574Component'
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/bin/../lib/gcc/xtensa-esp32s3-elf/8.4.0/../../../../xtensa-esp32s3-elf/bin/ld: .pioenvs/controller_avs412/src/main.o:(.literal._Z5setupv+0x1f4): undefined reference to `vtable for esphome::pcf8574::PCF8574GPIOPin'
collect2: error: ld returned 1 exit status
*** [.pioenvs/controller_avs412/firmware.elf] Error 1
========================= [FAILED] Took 11.95 seconds =========================
Can anyone tell you what's going wrong?
Thank you.
Dependency Graph
|-- noise-c @ 0.1.4
Thank you.
# Diversen I/O Modules.
# IP range gereserveerd van 192.168.200.101 t/m 192.168.200.109
friendly_name: CONTROLLER_AVS412
platformio_options:
board_build.flash_mode: dio
board: esp32-s3-devkitc-1
type: esp-idf
# Instellen I/O voor de RJ45 poort
type: W5500
clk_pin: GPIO43
mosi_pin: GPIO44
miso_pin: GPIO42
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
# Instellen statisch IP adres
manual_ip:
static_ip: 192.168.200.101
gateway: 192.168.200.1
subnet: 255.255.255.0
encryption:
key: "pKeAagi+vmlVVS45THS6padK2DpyOx+KYxlztZsxvQo="
ota:
sda: GPIO39
scl: GPIO38
# id: bus_a
address: 0x20 #replace by your PCF8574 address
# Activeren Web server.
web_server:
port: 80
# Instellen seriele communicatiepoort voor RS485
uart:
- id: uart_485
baud_rate: 9600
debug:
direction: BOTH
dummy_receiver: true
after:
timeout: 10ms
tx_pin: 16
rx_pin: 15
# Instellen seriele communicatiepoort voor de 4G communicatiemodule
- id: uart_sim7600
baud_rate: 115200
debug:
direction: BOTH
after:
timeout: 10ms
sequence:
tx_pin: 18
rx_pin: 17
# Software schakelaars voor RS485 en de 4G module aan/ uit te zetten
- platform: uart
uart_id: uart_485
- platform: uart
uart_id: uart_sim7600
data: "AT+CGSN\r\n" # read 4G SIM7600 ID
# In- en uitgangen instellen
number: 8
number: 40
#- platform: gpio
# name: "ESP_CPU01_AVS412 SDA"
# pin:
# number: 39
# inverted: true
# mode:
# input: true
# pullup: true
#- platform: gpio
# name: "ESP_CPU01_AVS412 SCL"
# pin:
# number: 38
# inverted: true
# mode:
# input: true
# pullup: true
number: 10
mode:
input: true
pullup: true
number: 11
mode:
input: true
pullup: true
number: 12
mode:
input: true
pullup: true
number: 13
mode:
input: true
pullup: true
number: 14
mode:
input: true
pullup: true
number: 21
mode:
input: true
pullup: true
number: 47
mode:
input: true
pullup: true
number: 48
mode:
input: true
pullup: true
pcf8574: pcf8574_hub_in_1
number: 4
number: 5
number: 6
number: 7
- platform: adc
pin: 4
name: "CONTROLLER_AVS412 IO04 Current"
update_interval: 2s
unit_of_measurement: V
attenuation: 11db
filters:
- multiply: 5
- platform: adc
pin: 5
name: "CONTROLLER_AVS412 IO05 Current"
update_interval: 2s
attenuation: 11db
filters:
- multiply: 5
- platform: adc
pin: 6
name: "CONTROLLER_AVS412 IO06 Current"
update_interval: 2s
attenuation: 11db
filters:
- multiply: 5
- platform: adc
pin: 7
name: "CONTROLLER_AVS412 IO07 Current"
update_interval: 2s
attenuation: 11db
filters:
- multiply: 5
