M30 configure yaml for ESPhome
yaml download:
.txt   M30_HA_LEDs.txt (Size: 49.87 KB / Downloads: 834)
modbus pull screen setting:
substitutions:
  max_current_range1: "10"
  max_current_range2: "10"
  max_current_range3: "10"
  max_current_range4: "10"
  max_current_range5: "10"
  max_current_range6: "10"
  max_current_range7: "10"
  max_current_range8: "10"
  max_current_range9: "10"
  max_current_range10: "10"
  max_current_range11: "10"
  max_current_range12: "10"
  max_current_range13: "10"
  max_current_range14: "10"
  max_current_range15: "10"
  max_current_range16: "10"
  max_current_range17: "10"
  max_current_range18: "10"
  max_current_range19: "10"
  max_current_range20: "10"
  max_current_range21: "10"
  max_current_range22: "10"
  max_current_range23: "10"
  max_current_range24: "10"
  max_current_range25: "10"
  max_current_range26: "10"
  max_current_range27: "10"
  max_current_range28: "10"
  max_current_range29: "10"
  max_current_range30: "10"
  friendly_name: m30
    type: arduino
  # baud_rate: 0
  encryption:
    key: "8G0kVEA0/DqgAavgKNyy9EYUrWo6pEZM38JVMAryJv8="
ota:
  password: "2a26484203d80a83798414c879541760"
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
uart:
  rx_pin: 32
  tx_pin: 33
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
modbus:
  uart_id: modbus_uart
modbus_controller:
  - id: modbus_hub_m30
    address: 1
    modbus_id: modbus_hub
    update_interval: 5s
  - platform: modbus_controller
    modbus_controller_id: modbus_hub_m30
    address: 100
    register_type: holding
    unit_of_measurement: A
    accuracy_decimals: 3
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_1).state;
              float red = (current - 0.0) / ${max_current_range1};
              float green = (${max_current_range1} - current) / ${max_current_range1};
              float blue = 0.0;
              auto call = id(M30_LED1).turn_on();
              call.set_brightness(0.6);
              call.set_rgb(red, green, blue);
              call.set_color_mode(ColorMode::RGB);
              call.perform();
    address: 101
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_2).state;
              float red = (current - 0.0) / ${max_current_range2};
              float green = (${max_current_range2} - current) / ${max_current_range2};
              float blue = 0.0;
              auto call = id(M30_LED2).turn_on();
              call.perform();
    address: 102
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_3).state;
              float red = (current - 0.0) / ${max_current_range3};
              float green = (${max_current_range3} - current) / ${max_current_range3};
              float blue = 0.0;
              auto call = id(M30_LED3).turn_on();
              call.perform();
    address: 103
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_4).state;
              float red = (current - 0.0) / ${max_current_range4};
              float green = (${max_current_range4} - current) / ${max_current_range4};
              float blue = 0.0;
              auto call = id(M30_LED4).turn_on();
              call.perform();
    address: 104
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_5).state;
              float red = (current - 0.0) / ${max_current_range5};
              float green = (${max_current_range5} - current) / ${max_current_range5};
              float blue = 0.0;
              auto call = id(M30_LED5).turn_on();
              call.perform();
    address: 105
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_6).state;
              float red = (current - 0.0) / ${max_current_range6};
              float green = (${max_current_range6} - current) / ${max_current_range6};
              float blue = 0.0;
              auto call = id(M30_LED6).turn_on();
              call.perform();
    address: 106
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_7).state;
              float red = (current - 0.0) / ${max_current_range7};
              float green = (${max_current_range7} - current) / ${max_current_range7};
              float blue = 0.0;
              auto call = id(M30_LED7).turn_on();
              call.perform();
    address: 107
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_8).state;
              float red = (current - 0.0) / ${max_current_range8};
              float green = (${max_current_range8} - current) / ${max_current_range8};
              float blue = 0.0;
              auto call = id(M30_LED8).turn_on();
              call.perform();
    address: 108
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_9).state;
              float red = (current - 0.0) / ${max_current_range9};
              float green = (${max_current_range9} - current) / ${max_current_range9};
              float blue = 0.0;
              auto call = id(M30_LED9).turn_on();
              call.perform();
    address: 109
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_1_current_10).state;
              float red = (current - 0.0) / ${max_current_range10};
              float green = (${max_current_range10} - current) / ${max_current_range10};
              float blue = 0.0;
              auto call = id(M30_LED10).turn_on();
              call.perform();
    address: 110
    unit_of_measurement: V
    accuracy_decimals: 1
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 111
    unit_of_measurement: W
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 112
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 113
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 114
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 115
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 116
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 117
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 118
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 119
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 120
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 121
    unit_of_measurement: kWh
    value_type: U_WORD
    address: 122
    value_type: U_WORD
    address: 123
    value_type: U_WORD
    address: 124
    value_type: U_WORD
    address: 125
    value_type: U_WORD
    address: 126
    value_type: U_WORD
    address: 127
    value_type: U_WORD
    address: 128
    value_type: U_WORD
    address: 129
    value_type: U_WORD
    address: 130
    value_type: U_WORD
    address: 131
    value_type: U_WORD
    address: 132
    unit_of_measurement: Hz
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 133
    unit_of_measurement: °C
    value_type: U_WORD
    filters:
      - multiply: 0.1
  # - platform: modbus_controller
  #  modbus_controller_id: modbus_hub_m30
  #  address: 134
  #  register_type: holding
  #  name: m30_1_tps_2
  #  id: m30_1_tps_2
  #  unit_of_measurement: °C
  #  accuracy_decimals: 1
  #  value_type: U_WORD
    address: 200
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_1).state;
              float red = (current - 0.0) / ${max_current_range11};
              float green = (${max_current_range11} - current) / ${max_current_range11};
              float blue = 0.0;
              auto call = id(M30_LED11).turn_on();
              call.perform();
    address: 201
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_2).state;
              float red = (current - 0.0) / ${max_current_range12};
              float green = (${max_current_range12} - current) / ${max_current_range12};
              float blue = 0.0;
              auto call = id(M30_LED12).turn_on();
              call.perform();
    address: 202
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_3).state;
              float red = (current - 0.0) / ${max_current_range13};
              float green = (${max_current_range13} - current) / ${max_current_range13};
              float blue = 0.0;
              auto call = id(M30_LED13).turn_on();
              call.perform();
    address: 203
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_4).state;
              float red = (current - 0.0) / ${max_current_range14};
              float green = (${max_current_range14} - current) / ${max_current_range14};
              float blue = 0.0;
              auto call = id(M30_LED14).turn_on();
              call.perform();
    address: 204
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_5).state;
              float red = (current - 0.0) / ${max_current_range15};
              float green = (${max_current_range15} - current) / ${max_current_range15};
              float blue = 0.0;
              auto call = id(M30_LED15).turn_on();
              call.perform();
    address: 205
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_6).state;
              float red = (current - 0.0) / ${max_current_range16};
              float green = (${max_current_range16} - current) / ${max_current_range16};
              float blue = 0.0;
              auto call = id(M30_LED16).turn_on();
              call.perform();
    address: 206
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_7).state;
              float red = (current - 0.0) / ${max_current_range17};
              float green = (${max_current_range17} - current) / ${max_current_range17};
              float blue = 0.0;
              auto call = id(M30_LED17).turn_on();
              call.perform();
    address: 207
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_8).state;
              float red = (current - 0.0) / ${max_current_range18};
              float green = (${max_current_range18} - current) / ${max_current_range18};
              float blue = 0.0;
              auto call = id(M30_LED18).turn_on();
              call.perform();
    address: 208
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_9).state;
              float red = (current - 0.0) / ${max_current_range19};
              float green = (${max_current_range19} - current) / ${max_current_range19};
              float blue = 0.0;
              auto call = id(M30_LED19).turn_on();
              call.perform();
    address: 209
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_2_current_10).state;
              float red = (current - 0.0) / ${max_current_range20};
              float green = (${max_current_range20} - current) / ${max_current_range20};
              float blue = 0.0;
              auto call = id(M30_LED20).turn_on();
              call.perform();
    address: 210
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 211
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 212
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 213
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 214
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 215
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 216
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 217
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 218
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 219
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 220
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 221
    value_type: U_WORD
    address: 222
    value_type: U_WORD
    address: 223
    value_type: U_WORD
    address: 224
    value_type: U_WORD
    address: 225
    value_type: U_WORD
    address: 226
    value_type: U_WORD
    address: 227
    value_type: U_WORD
    address: 228
    value_type: U_WORD
    address: 229
    value_type: U_WORD
    address: 230
    value_type: U_WORD
    address: 231
    value_type: U_WORD
    address: 232
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 233
    value_type: U_WORD
    filters:
      - multiply: 0.1
  #  address: 234
  #  name: m30_2_tps_2
  #  id: m30_2_tps_2
    address: 300
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_1).state;
              float red = (current - 0.0) / ${max_current_range21};
              float green = (${max_current_range21} - current) / ${max_current_range21};
              float blue = 0.0;
              auto call = id(M30_LED21).turn_on();
              call.perform();
    address: 301
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_2).state;
              float red = (current - 0.0) / ${max_current_range22};
              float green = (${max_current_range22} - current) / ${max_current_range22};
              float blue = 0.0;
              auto call = id(M30_LED22).turn_on();
              call.perform();
    address: 302
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_3).state;
              float red = (current - 0.0) / ${max_current_range23};
              float green = (${max_current_range23} - current) / ${max_current_range23};
              float blue = 0.0;
              auto call = id(M30_LED23).turn_on();
              call.perform();
    address: 303
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_4).state;
              float red = (current - 0.0) / ${max_current_range24};
              float green = (${max_current_range24} - current) / ${max_current_range24};
              float blue = 0.0;
              auto call = id(M30_LED24).turn_on();
              call.perform();
    address: 304
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_5).state;
              float red = (current - 0.0) / ${max_current_range25};
              float green = (${max_current_range25} - current) / ${max_current_range25};
              float blue = 0.0;
              auto call = id(M30_LED25).turn_on();
              call.perform();
    address: 305
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_6).state;
              float red = (current - 0.0) / ${max_current_range26};
              float green = (${max_current_range26} - current) / ${max_current_range26};
              float blue = 0.0;
              auto call = id(M30_LED26).turn_on();
              call.perform();
    address: 306
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_7).state;
              float red = (current - 0.0) / ${max_current_range27};
              float green = (${max_current_range27} - current) / ${max_current_range27};
              float blue = 0.0;
              auto call = id(M30_LED27).turn_on();
              call.perform();
    address: 307
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_8).state;
              float red = (current - 0.0) / ${max_current_range28};
              float green = (${max_current_range28} - current) / ${max_current_range28};
              float blue = 0.0;
              auto call = id(M30_LED28).turn_on();
              call.perform();
    address: 308
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_9).state;
              float red = (current - 0.0) / ${max_current_range29};
              float green = (${max_current_range29} - current) / ${max_current_range29};
              float blue = 0.0;
              auto call = id(M30_LED29).turn_on();
              call.perform();
    address: 309
    value_type: U_WORD
    filters:
      - multiply: 0.00098
    on_value:
      - then:
          - lambda: |-
              float current = id(m30_3_current_10).state;
              float red = (current - 0.0) / ${max_current_range30};
              float green = (${max_current_range30} - current) / ${max_current_range30};
              float blue = 0.0;
              auto call = id(M30_LED30).turn_on();
              call.perform();
    address: 310
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 311
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 312
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 313
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 314
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 315
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 316
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 317
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 318
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 319
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 320
    value_type: U_WORD
    filters:
      - multiply: 0.1
    address: 321
    value_type: U_WORD
    address: 322
    value_type: U_WORD
    address: 323
    value_type: U_WORD
    address: 324
    value_type: U_WORD
    address: 325
    value_type: U_WORD
    address: 326
    value_type: U_WORD
    address: 327
    value_type: U_WORD
    address: 328
    value_type: U_WORD
    address: 329
    value_type: U_WORD
    address: 330
    value_type: U_WORD
    address: 331
    value_type: U_WORD
    address: 332
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 333
    value_type: U_WORD
    filters:
      - multiply: 0.1
  #  address: 334
  #  name: m30_3_tps_2
  #  id: m30_3_tps_2
light:
  - platform: partition
    segments:
      - id: light1
        to: 14
    segments:
      - id: light1
        to: 13
    segments:
      - id: light1
        to: 12
    segments:
      - id: light1
        to: 11
    segments:
      - id: light1
        to: 10
    segments:
      - id: light1
        to: 9
    segments:
      - id: light1
        to: 8
    segments:
      - id: light1
        to: 7
    segments:
      - id: light1
        to: 6
    segments:
      - id: light1
        to: 5
    segments:
      - id: light1
        to: 4
    segments:
      - id: light1
        to: 3
    segments:
      - id: light1
        to: 2
    segments:
      - id: light1
        to: 1
    segments:
      - id: light1
        to: 0
    segments:
      - id: light1
        to: 15
    segments:
      - id: light1
        to: 16
    segments:
      - id: light1
        to: 17
    segments:
      - id: light1
        to: 18
    segments:
      - id: light1
        to: 19
    segments:
      - id: light1
        to: 20
    segments:
      - id: light1
        to: 21
    segments:
      - id: light1
        to: 22
    segments:
      - id: light1
        to: 23
    segments:
      - id: light1
        to: 24
    segments:
      - id: light1
        to: 25
    segments:
      - id: light1
        to: 26
    segments:
      - id: light1
        to: 27
    segments:
      - id: light1
        to: 28
    segments:
      - id: light1
        to: 29
  # Example for light segment source
  - platform: esp32_rmt_led_strip
    rgb_order: GRB
    pin: GPIO12
    num_leds: 30
    rmt_channel: 0
    chipset: ws2812
new yaml support add to "Energy" dashboard in home assistant.
.txt   M30_HA_LEDs.txt (Size: 51.65 KB / Downloads: 641)
When I try to upload this yaml, I get the error: "Wrong Magic Byte".
upload your yaml file at here.
It is exactly the same file uploaded above - I have not made any changes.
you can contact by whatsapp number: +86-15381188302 when have free time, we can use ANYDESK remote control your computer to help you.
I think I've figured it out. There were two breaking changes in the yaml/compile step. One is the "ota" key requires "platform", and the other is the ota upload reqires a different bin file. (in .esphome/build/m30/.pioenvs/m30/firmware.ota.bin). so the yaml change needed is to change:
ota:
to:
ota:
platform: esphome
ok, good.
For the yaml lines:
Should the "10" be replaced with the max capacity of the CT clamp, or the capacity of the circuit?
For example, If I put a 25A CT clamp on a 15A circuit, should the yaml be "25" or "15"?
Within the yaml, I see these values are only used to compute the LED color, are they used in the firmware for anything?
"max_current_range1" only use for LED color, so that can change color for GREEN to RED. not used by firmware other function.
