11-28-2024, 11:44 AM
* RS485 Communication Test
* The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 17
#define RS485_TXD 16
while (!Serial);
// Send a test message
rs485Serial.println("Hello from KinCony F16!");
// Wait for a short period
delay(1000);
String receivedMessage = "";
char c = rs485Serial.read();
receivedMessage += c;
// Print the received message
Serial.print("Received: ");
delay(2000);
4-RS485-Test.zip (Size: 763 bytes / Downloads: 525)
