change wake up name
#11
No I dont know how to modify
I have followed your instructions from your links you have given me.
I have followed your instructions from your links you have given me .
Do you using KC868-AIO?
(12-17-2024, 11:38 PM)admin Wrote: Do you using KC868-AIO?
Yes
here is feedback from KC868-AIO mqtt state:
{"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},"input6":{"value":false},"input7":{"value":false},"input8":{"value":false},"input9":{"value":false},"input10":{"value":false},"input11":{"value":false},"input12":{"value":false},"input13":{"value":false},"input14":{"value":false},"input15":{"value":false},"input16":{"value":false},"input17":{"value":false},"input18":{"value":false},"input19":{"value":false},"input20":{"value":false},"input21":{"value":false},"input22":{"value":false},"input23":{"value":false},"input24":{"value":false},"input25":{"value":false},"input26":{"value":false},"input27":{"value":false},"input28":{"value":false},"input29":{"value":false},"input30":{"value":false},"input31":{"value":false},"input32":{"value":false},"input33":{"value":false},"input34":{"value":false},"input35":{"value":false},"input36":{"value":false},"input37":{"value":false},"input38":{"value":false},"input39":{"value":false},"input40":{"value":false},"input41":{"value":false},"input42":{"value":false},"input43":{"value":false},"input44":{"value":false},"input45":{"value":false},"input46":{"value":false},"input47":{"value":false},"input48":{"value":false},"input49":{"value":false},"input50":{"value":false},"input51":{"value":false},"input52":{"value":false},"input53":{"value":false},"input54":{"value":false},"input55":{"value":false},"input56":{"value":false},"output1":{"value":false},"output2":{"value":false},"output3":{"value":false},"output4":{"value":false},"output5":{"value":false},"output6":{"value":false},"output7":{"value":false},"output8":{"value":false},"output9":{"value":false},"output10":{"value":false},"output11":{"value":false},"output12":{"value":false},"output13":{"value":false},"output14":{"value":false},"output15":{"value":false},"output16":{"value":false},"output17":{"value":false},"output18":{"value":false},"output19":{"value":false},"output20":{"value":false},"output21":{"value":false},"output22":{"value":false},"output23":{"value":false},"output24":{"value":false},"output25":{"value":false},"output26":{"value":false},"output27":{"value":false},"output28":{"value":false},"output29":{"value":false},"output30":{"value":false},"output31":{"value":false},"output32":{"value":false},"adc1":{"value":0},"adc2":{"value":0},"adc3":{"value":0},"adc4":{"value":0},"adc5":{"value":0},"adc6":{"value":0},"adc7":{"value":0},"adc8":{"value":0},"adc9":{"value":0},"adc10":{"value":0},"adc11":{"value":0},"adc12":{"value":0},"adc13":{"value":0},"adc14":{"value":0},"adc15":{"value":0},"adc16":{"value":0},"adc17":{"value":0},"adc18":{"value":0},"adc19":{"value":0},"dac1":{"value":0},"dac2":{"value":0},"dac3":{"value":0},"dac4":{"value":0},"dac5":{"value":0},"dac6":{"value":0},"dac7":{"value":0},"dac8":{"value":0},"dac9":{"value":0},"dac10":{"value":0},"dac11":{"value":0},"dac12":{"value":0},"dac13":{"value":0},"dac14":{"value":0},"dac15":{"value":0},"dac16":{"value":0},"sensor1":{"temperature":-100.0,"humidity":-100.0},"sensor2":{"temperature":-100.0,"humidity":-100.0}}
so you can modify the yaml by this way. here is yaml for KC868-AIO, it config for 32 channel digital output and 56 channel digital input ports. You ONLY need to replace with your own UID in "command_topic" and "state_topic" topic.
default_config:
frontend:
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt:
   - name: 'aio-kcs-output-1'
     unique_id: aio-kcs-output-1
     state_topic: 'KC868_AIO/08F9E08BCB74/STATE'
     command_topic: 'KC868_AIO/08F9E08BCB74/SET'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-2'
     unique_id: aio-kcs-output-2
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-3'
     unique_id: aio-kcs-output-3
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-4'
     unique_id: aio-kcs-output-4
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-5'
     unique_id: aio-kcs-output-5
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-6'
     unique_id: aio-kcs-output-6
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-7'
     unique_id: aio-kcs-output-7
     payload_on:  '{"output7":{"value":true}}'
     payload_off:  '{"output7":{"value":false}}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-8'
     unique_id: aio-kcs-output-8
     payload_on:  '{"output8":{"value":true}}'
     payload_off:  '{"output8":{"value":false}}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-9'
     unique_id: aio-kcs-output-9
     payload_on:  '{"output9":{"value":true}}'
     payload_off:  '{"output9":{"value":false}}'
     value_template: '{{ value_json.output9.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-10'
     unique_id: aio-kcs-output-10
     payload_on:  '{"output10":{"value":true}}'
     payload_off:  '{"output10":{"value":false}}'
     value_template: '{{ value_json.output10.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-11'
     unique_id: aio-kcs-output-11
     payload_on:  '{"output11":{"value":true}}'
     payload_off:  '{"output11":{"value":false}}'
     value_template: '{{ value_json.output11.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-12'
     unique_id: aio-kcs-output-12
     payload_on:  '{"output12":{"value":true}}'
     payload_off:  '{"output12":{"value":false}}'
     value_template: '{{ value_json.output12.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-13'
     unique_id: aio-kcs-output-13
     payload_on:  '{"output13":{"value":true}}'
     payload_off:  '{"output13":{"value":false}}'
     value_template: '{{ value_json.output13.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-14'
     unique_id: aio-kcs-output-14
     payload_on:  '{"output14":{"value":true}}'
     payload_off:  '{"output14":{"value":false}}'
     value_template: '{{ value_json.output14.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-15'
     unique_id: aio-kcs-output-15
     payload_on:  '{"output15":{"value":true}}'
     payload_off:  '{"output15":{"value":false}}'
     value_template: '{{ value_json.output15.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-16'
     unique_id: aio-kcs-output-16
     payload_on:  '{"output16":{"value":true}}'
     payload_off:  '{"output16":{"value":false}}'
     value_template: '{{ value_json.output16.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-17'
     unique_id: aio-kcs-output-17
     payload_on:  '{"output17":{"value":true}}'
     payload_off:  '{"output17":{"value":false}}'
     value_template: '{{ value_json.output17.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-18'
     unique_id: aio-kcs-output-18
     payload_on:  '{"output18":{"value":true}}'
     payload_off:  '{"output18":{"value":false}}'
     value_template: '{{ value_json.output18.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-19'
     unique_id: aio-kcs-output-19
     payload_on:  '{"output19":{"value":true}}'
     payload_off:  '{"output19":{"value":false}}'
     value_template: '{{ value_json.output19.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-20'
     unique_id: aio-kcs-output-20
     payload_on:  '{"output20":{"value":true}}'
     payload_off:  '{"output20":{"value":false}}'
     value_template: '{{ value_json.output20.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-21'
     unique_id: aio-kcs-output-21
     payload_on:  '{"output21":{"value":true}}'
     payload_off:  '{"output21":{"value":false}}'
     value_template: '{{ value_json.output21.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-22'
     unique_id: aio-kcs-output-22
     payload_on:  '{"output22":{"value":true}}'
     payload_off:  '{"output22":{"value":false}}'
     value_template: '{{ value_json.output22.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-23'
     unique_id: aio-kcs-output-23
     payload_on:  '{"output23":{"value":true}}'
     payload_off:  '{"output23":{"value":false}}'
     value_template: '{{ value_json.output23.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-24'
     unique_id: aio-kcs-output-24
     payload_on:  '{"output24":{"value":true}}'
     payload_off:  '{"output24":{"value":false}}'
     value_template: '{{ value_json.output24.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-25'
     unique_id: aio-kcs-output-25
     payload_on:  '{"output25":{"value":true}}'
     payload_off:  '{"output25":{"value":false}}'
     value_template: '{{ value_json.output25.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-26'
     unique_id: aio-kcs-output-26
     payload_on:  '{"output26":{"value":true}}'
     payload_off:  '{"output26":{"value":false}}'
     value_template: '{{ value_json.output26.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-27'
     unique_id: aio-kcs-output-27
     payload_on:  '{"output27":{"value":true}}'
     payload_off:  '{"output27":{"value":false}}'
     value_template: '{{ value_json.output27.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-28'
     unique_id: aio-kcs-output-28
     payload_on:  '{"output28":{"value":true}}'
     payload_off:  '{"output28":{"value":false}}'
     value_template: '{{ value_json.output28.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-29'
     unique_id: aio-kcs-output-29
     payload_on:  '{"output29":{"value":true}}'
     payload_off:  '{"output29":{"value":false}}'
     value_template: '{{ value_json.output29.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-30'
     unique_id: aio-kcs-output-30
     payload_on:  '{"output30":{"value":true}}'
     payload_off:  '{"output30":{"value":false}}'
     value_template: '{{ value_json.output30.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-31'
     unique_id: aio-kcs-output-31
     payload_on:  '{"output31":{"value":true}}'
     payload_off:  '{"output31":{"value":false}}'
     value_template: '{{ value_json.output31.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-output-32'
     unique_id: aio-kcs-output-32
     payload_on:  '{"output32":{"value":true}}'
     payload_off:  '{"output32":{"value":false}}'
     value_template: '{{ value_json.output32.value }}'
     state_on: true
     state_off: false
   - name: 'aio-kcs-input-1'
     unique_id: aio-kcs-input-1
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-2'
     unique_id: aio-kcs-input-2
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-3'
     unique_id: aio-kcs-input-3
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-4'
     unique_id: aio-kcs-input-4
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-5'
     unique_id: aio-kcs-input-5
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-6'
     unique_id: aio-kcs-input-6
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-7'
     unique_id: aio-kcs-input-7
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-8'
     unique_id: aio-kcs-input-8
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-9'
     unique_id: aio-kcs-input-9
     value_template: '{{ value_json.input9.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-10'
     unique_id: aio-kcs-input-10
     value_template: '{{ value_json.input10.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-11'
     unique_id: aio-kcs-input-11
     value_template: '{{ value_json.input11.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-12'
     unique_id: aio-kcs-input-12
     value_template: '{{ value_json.input12.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-13'
     unique_id: aio-kcs-input-13
     value_template: '{{ value_json.input13.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-14'
     unique_id: aio-kcs-input-14
     value_template: '{{ value_json.input14.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-15'
     unique_id: aio-kcs-input-15
     value_template: '{{ value_json.input15.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-16'
     unique_id: aio-kcs-input-16
     value_template: '{{ value_json.input16.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-17'
     unique_id: aio-kcs-input-17
     value_template: '{{ value_json.input17.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-18'
     unique_id: aio-kcs-input-18
     value_template: '{{ value_json.input18.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-19'
     unique_id: aio-kcs-input-19
     value_template: '{{ value_json.input19.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-20'
     unique_id: aio-kcs-input-20
     value_template: '{{ value_json.input20.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-21'
     unique_id: aio-kcs-input-21
     value_template: '{{ value_json.input21.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-22'
     unique_id: aio-kcs-input-22
     value_template: '{{ value_json.input22.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-23'
     unique_id: aio-kcs-input-23
     value_template: '{{ value_json.input23.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-24'
     unique_id: aio-kcs-input-24
     value_template: '{{ value_json.input24.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-25'
     unique_id: aio-kcs-input-25
     value_template: '{{ value_json.input25.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-26'
     unique_id: aio-kcs-input-26
     value_template: '{{ value_json.input26.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-27'
     unique_id: aio-kcs-input-27
     value_template: '{{ value_json.input27.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-28'
     unique_id: aio-kcs-input-28
     value_template: '{{ value_json.input28.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-29'
     unique_id: aio-kcs-input-29
     value_template: '{{ value_json.input29.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-30'
     unique_id: aio-kcs-input-30
     value_template: '{{ value_json.input30.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-31'
     unique_id: aio-kcs-input-31
     value_template: '{{ value_json.input31.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-32'
     unique_id: aio-kcs-input-32
     value_template: '{{ value_json.input32.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-33'
     unique_id: aio-kcs-input-33
     value_template: '{{ value_json.input33.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-34'
     unique_id: aio-kcs-input-34
     value_template: '{{ value_json.input34.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-35'
     unique_id: aio-kcs-input-35
     value_template: '{{ value_json.input35.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-36'
     unique_id: aio-kcs-input-36
     value_template: '{{ value_json.input36.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-37'
     unique_id: aio-kcs-input-37
     value_template: '{{ value_json.input37.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-38'
     unique_id: aio-kcs-input-38
     value_template: '{{ value_json.input38.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-39'
     unique_id: aio-kcs-input-39
     value_template: '{{ value_json.input39.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-40'
     unique_id: aio-kcs-input-40
     value_template: '{{ value_json.input40.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-41'
     unique_id: aio-kcs-input-41
     value_template: '{{ value_json.input41.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-42'
     unique_id: aio-kcs-input-42
     value_template: '{{ value_json.input42.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-43'
     unique_id: aio-kcs-input-43
     value_template: '{{ value_json.input43.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-44'
     unique_id: aio-kcs-input-44
     value_template: '{{ value_json.input44.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-45'
     unique_id: aio-kcs-input-45
     value_template: '{{ value_json.input45.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-46'
     unique_id: aio-kcs-input-46
     value_template: '{{ value_json.input46.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-47'
     unique_id: aio-kcs-input-47
     value_template: '{{ value_json.input47.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-48'
     unique_id: aio-kcs-input-48
     value_template: '{{ value_json.input48.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-49'
     unique_id: aio-kcs-input-49
     value_template: '{{ value_json.input49.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-50'
     unique_id: aio-kcs-input-50
     value_template: '{{ value_json.input50.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-51'
     unique_id: aio-kcs-input-51
     value_template: '{{ value_json.input51.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-52'
     unique_id: aio-kcs-input-52
     value_template: '{{ value_json.input52.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-53'
     unique_id: aio-kcs-input-53
     value_template: '{{ value_json.input53.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-54'
     unique_id: aio-kcs-input-54
     value_template: '{{ value_json.input54.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-55'
     unique_id: aio-kcs-input-55
     value_template: '{{ value_json.input55.value }}'
     payload_on: true
     payload_off: false
   - name: 'aio-kcs-input-56'
     unique_id: aio-kcs-input-56
     value_template: '{{ value_json.input56.value }}'
     payload_on: true
     payload_off: false
yaml file download:
.txt   AIO-mqtt-HA.txt (Size: 23.81 KB / Downloads: 374)
check your own UID of KC868-AIO at INDEX webpage.
Hi
Thanks for your reply and support all working great now.
I have Sensors that I would like to add to the kc868 aio, eg- water temperature sensors ,temperature and humidity sensors, water level sensors and human presence sensors that I have purchased from you, how do I integrate these to the aio using kcs firmware.
water temperature sensors ,temperature and humidity sensors, water level sensors need all details. such as which are analog 0-5v sensor? which is DS18B20? human presence sensor just connect to your digital input port.
(12-20-2024, 12:15 AM)admin Wrote: water temperature sensors ,temperature and humidity sensors, water level sensors need all details. such as which are analog 0-5v sensor? which is DS18B20? human presence sensor just connect to your digital input port.
These are all the sensors ,that I would like to integrate to the kc868AIO which I am running on the kcs firmware.
when i have free time, will update the yaml for use these sensor. the last one, VALVE is not a sensor, you can connect with relay output port to drive it.
(12-20-2024, 12:52 PM)admin Wrote: when i have free time, will update the yaml for use these sensor. the last one, VALVE is not a sensor, you can connect with relay output port to drive it.
Ok, Thank you.
I have just received my b16m and f24 today all installed all working ok .
I want to get my door access keypad put on to the B16m using wiegand , I have installed the B16m to esphome to do this as you mentioned before I cannot use this if I have Kcs firmware installed is that correct?, what 2 gpios do I use on the B16m for the 2 data wires from the access control keypad?
Thanks for your support much appreciated.
KCS firmware not support wiegand directly, maybe in future will update for that.
now you can config by ESPHome, if you want to use wiegand device. any free GPIOs can be used by wiegand device.
