Threads: 13
hi,
i have two H32L + esp32 tuya that i have already brought to Home Assistant. in the screen however i see only 5 switches, how can i see them all and also customize those seen in home?
Threads: 1,560
take a photo of your screen. where is 5 switch.
Threads: 1,560
do you integrate to home assistant by MQTT? if YES, post your yaml file.
Threads: 13
12-21-2024, 08:29 AM
(This post was last modified: 12-21-2024, 08:31 AM by athxp.)
I don't know what it is, I ported via tuya local
Threads: 1,560
i have not used integrate with Tuya.
Threads: 13
How can I see all the buttons?
Threads: 1,560
i don't know you how to use tuya? by tuya adapter?
Threads: 13
how can i bring h32L to home assistant? via tuya it brought me only 4 buttons
Threads: 1,560
H32L old controller work with home assistant, It's quite complex and the stability is not very good. so that suggest use old controller work with home assistant. If use H32B / H32B Pro work with mqtt is better.
