"KCS" v2.2.10 firmware BIN file download
v2.2.10 improvement:
1. Fix the problem that multiple DI false configurations in ifttt cannot work well.
2. Fix the problem that ifttt processing will be blocked when mqtt is disconnected
.zip   KCS_KC868_A32_V2.2.10.zip (Size: 786.31 KB / Downloads: 1,019)
.zip   KCS_KC868_A32M_V2.2.10.zip (Size: 804.31 KB / Downloads: 795)
.zip   KCS_KC868_A64_V2.2.10.zip (Size: 786.62 KB / Downloads: 907)
.zip   KCS_KC868_A128_V2.2.10.zip (Size: 786.19 KB / Downloads: 879)
.zip   KCS_KC868_AG_V2.2.10.zip (Size: 764.43 KB / Downloads: 932)
.zip   KCS_KC868_AI_V2.2.10.zip (Size: 789.12 KB / Downloads: 882)
.zip   KCS_KC868_AIO_V2.2.10.zip (Size: 806.16 KB / Downloads: 844)
.zip   KCS_KC868_AK_V2.2.10.zip (Size: 766.85 KB / Downloads: 847)
.zip   KCS_KC868_AM_V2.2.10.zip (Size: 781.85 KB / Downloads: 826)
.zip   KCS_KC868_AP_V2.2.10.zip (Size: 784.5 KB / Downloads: 814)
.zip   KCS_KC868_ASR_V2.2.10.zip (Size: 761.24 KB / Downloads: 870)
.zip   KCS_KC868_E16S_V2.2.10.zip (Size: 791.25 KB / Downloads: 849)
.zip   KCS_KC868_UAIR_V2.2.10.zip (Size: 767.77 KB / Downloads: 888)
.zip   KCS_KC868_A2_V2.2.10.zip (Size: 794.89 KB / Downloads: 861)
.zip   KCS_KC868_A4_V2.2.10.zip (Size: 781.89 KB / Downloads: 914)
.zip   KCS_KC868_A4S_V2.2.10.zip (Size: 805.4 KB / Downloads: 903)
.zip   KCS_KC868_A6_V2.2.10.zip (Size: 780.15 KB / Downloads: 1,202)
.zip   KCS_KC868_A8_V2.2.10.zip (Size: 788.76 KB / Downloads: 972)
.zip   KCS_KC868_A8M_V2.2.10.zip (Size: 804.97 KB / Downloads: 862)
.zip   KCS_KC868_A8S_V2.2.10.zip (Size: 806.63 KB / Downloads: 868)
.zip   KCS_KC868_A16_V2.2.10.zip (Size: 796.35 KB / Downloads: 1,375)
.zip   KCS_KC868_A16S_V2.2.10.zip (Size: 806.56 KB / Downloads: 879)
UTC time setting and display on `index.html` page is still broken.
I have 2 new KC868_A16 boards and each have a different, *wrong* calculation for UTC-N time offsets.
Specifically,
- On one board, UTC-N gives UTC-(N+1). E.g., I am in Americas/New_York which is now on EST which is UTC-5 but when set to UTC-5, the time reads as UTC-4
- On another board, UTC-N give UTC-(N-8). E.g., I am in Americas/New_York which is now on EST which is UTC-5 but when set to UTC-5, the time reads as UTC-13
Also the display of time (under `index.html`) is non-standard. Specifically, it doesn't force 2 digits for the display of seconds, minutes (or hours).
For example: 4:07:05 reads as: 4:7:5 which is totally non-standard.
This should be a pretty simple bug in the code to correct as it just requires the correct arithmetic to add/subtract from UTC hours plus the correct formatting of the time printout.
Note I am using FW 2.2.10
UTC issue will fix in next update version.
Hello, are there any plans to prepare software for the M16 board?
HI EVERYONE, I'M LOOKING FOR THE LATEST FIRMWARE FOR THE KC868_A24 BOARD, CAN ANYONE HELP ME?
(01-10-2025, 09:20 AM)105Timi Wrote: Hello, are there any plans to prepare software for the M16 board?
no this plan, develop firmware based on M30 series.
here is A24 firmware:
.zip   KCS_A24_V2.2.2.zip (Size: 747.66 KB / Downloads: 745)
Will it be possible to use it with M16 inserts?
no, can't .
