M30 negative power
Hi
have the M30  V2.4.10
One clamp is in postive direction one in negative installed, but have always positive power at display.
I can not get negative power. What can this be?
you can try to test with V2.4.7: https://www.kincony.com/forum/showthread.php?tid=6604
make sure your CT clamp is 2000:1, so that can use for M30 board.
you can test "postive direction" and "negative direction" by one CT sensor.
Hi
got it running.
On purchased part old Bootloader was on it.
With new one it is now working
ok
