Sim7600E kc868_A4S GSM SIM Internet Is not working - 4G and 3G Enabled
Hi, I am Sim7600E kc868_A4S Model to call website URL after Internet activation.
SIM Yellow Light is blinking.
SIM call and SMS are working. But, Internet is not working. I have changed SIM Provider APN details
#include <HardwareSerial.h>
// Define SIM7600 UART
#define MODEM_RX 13   // Connect to SIM7600 TX
#define MODEM_TX 15   // Connect to SIM7600 RX
HardwareSerial sim7600(1);  // Use UART1
const char* APN = "du";    // Set your network APN
const char* USER = "";     // Usually blank
const char* PASS = "";     // Usually blank
  Serial.begin(115200);           // USB serial
  sim7600.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX); // UART1
  delay(5000);  // Give time to power up
  Serial.println("Initializing SIM7600...");
  // Disable echo for clean output
  sendATCommand("ATE0", "OK", 1000);
  // Basic check
  if (!retryCommand("AT", "OK", 2000, 3)) {
    Serial.println("SIM7600 not responding!");
    while (1);
  // SIM card check
  if (!sendATCommand("AT+CPIN?", "READY", 2000)) {
    Serial.println("SIM Card not ready!");
    while (1);
  // Set LTE-only mode
  sendATCommand("AT+CNMP=38", "OK", 3000);
  sendATCommand("AT+CMNB=1", "OK", 3000);
  // Set APN
  String apnCmd = "AT+CGDCONT=1,\"IP\",\"" + String(APN) + "\"";
  sendATCommand(apnCmd.c_str(), "OK", 3000);
  // Attach to network
  if (!sendATCommand("AT+CGATT=1", "OK", 10000)) {
    Serial.println("Failed to attach to network!");
    while (1);
  // Activate PDP
  if (!sendATCommand("AT+CGACT=1,1", "OK", 10000)) {
    Serial.println("Failed to activate PDP!");
    while (1);
  // Show IP
  printIPAddress();
  // Optional: monitor SIM7600 data or implement HTTP
// ========== AT COMMAND HELPERS ==========
bool sendATCommand(const char* cmd, const char* expected, uint32_t timeout) {
  sim7600.flush();
  sim7600.println(cmd);
  Serial.print(">> "); Serial.println(cmd);
  uint32_t start = millis();
  String response;
  while (millis() - start < timeout) {
    while (sim7600.available()) {
      char c = sim7600.read();
      Serial.write©;
      response += c;
      if (response.indexOf(expected) != -1) {
        return true;
  Serial.println("\n!! Timeout or Unexpected response:");
  Serial.println(response);
  return false;
bool retryCommand(const char* cmd, const char* expected, uint32_t timeout, int retries) {
  for (int i = 0; i < retries; i++) {
    if (sendATCommand(cmd, expected, timeout)) return true;
    delay(1000);
  return false;
void printIPAddress() {
  Serial.println("Checking IP with AT+CGPADDR=1...");
  sim7600.println("AT+CGPADDR=1");
  delay(1000);
  String response;
    Serial.write©;
    response += c;
  int ipStart = response.indexOf(",\"") + 2;
  int ipEnd = response.indexOf("\"", ipStart);
  if (ipStart > 1 && ipEnd > ipStart) {
    String ip = response.substring(ipStart, ipEnd);
    Serial.print("Assigned IP: ");
    Serial.println(ip);
  } else {
    Serial.println("No IP Address Assigned");
OutPut
13:57:40.249 -> >> AT
13:57:42.215 -> !! Timeout or Unexpected response:
13:57:49.212 -> SIM7600 not responding!
Note : SIM calling is working
Note 2: SIM SMS are working.
Only Internet is not activated. I have to call website URL after Internet connected.
we have demo code for SMS and CALL. SIM7600 support MQTT connection. what function you want to use? do you want use SIM7600 to visite internet webpage? or ?
Hi , Thank you for Reply.
I have to Send call API URL with Post JSON Data  and Connect WiFiClient socket for Heartbeat and communication purpose.
HTTPClient http;
WiFiClient client;
client.connect(serverIP, 80);
void sendTelemetry() {
  HTTPClient http;
  DynamicJsonDocument doc(512);
  doc["serialNumber"] = device_serial_number;  // alarmSystem.config.deviceID;
  doc["temperature"] = alarmSystem.sensors.temperature;
  doc["humidity"] = alarmSystem.sensors.humidity;
  doc["current_mA"] = alarmSystem.sensors.current_mA;
  doc["status"] = static_cast<int>(alarmSystem.currentState);
  doc["doorOpen"] = alarmSystem.sensors.doorOpen ? 1 : 0;
  doc["waterLeakage"] = alarmSystem.sensors.waterLeak ? 1 : 0;
  doc["acPowerFailure"] = alarmSystem.sensors.powerFail ? 1 : 0;
  doc["fire"] = alarmSystem.sensors.fire ? 1 : 0;
  doc["temperature_alarm"] = 0;
  if (alarmSystem.sensors.temperature > alarmSystem.config.tempThreshold) {
    doc["temperature_alarm"] = 1;
  String payload;
  serializeJson(doc, payload);
  sensorData=payload;
  http.begin(serverURL + "/alarm_device_status");
  http.addHeader("Content-Type", "application/json");
  int httpCode = http.POST(payload);
  //Serial.println(serverURL);
  if (httpCode > 0) {
    Serial.println("HTTP Response: " + String(httpCode));
  } else {
    Serial.println("HTTP Error: " + String(httpCode));
  http.end();
Can I use Configure PPP connection?
i am not tested with pppoe connection, only have used mqtt. if esp32 work as a router with sim7600e, i think it's not very suitable.
