b16m programing blinds
#11
Can you give me instructions how to pair both b16m using http or UDP and how to add both b16m to Homeassistant?
if you want two B16M work with home assistant, it's very easy, just two B16M ethernet or wifi all connect with same router. all kincony controller will auto discovery in home assistant if you downloaded KCS v3 firmware. they will have different name in home assistant.
Can you help me connect to Homeassistant?
install mosquito mqtt broker on your home assistant. then set the mosquito broker ip , port, user name, password in webpage.
[Image: protocol-general.png]
After updating the software to V3.9.2. I have a problem with rebooting. After triggering the digital outputs, the controller restarts itself, this is a big problem for me because the controller would have to manage a luxury villa, so it is not desirable for this to happen.
I can't attach the video because the file is too large.
do you have send video to us by messenger? we have seen the video.
what power supply you are using? do you have connect power with "DC" terminal by one power supply?
MZMW UPS/Charge Function Switching Power Supply SC- 180W 12V
