Problems wifi / ESPHome?
Exclamation
Can somebody test my code my wifi is dropping and cant connect to it after the update esphome
ESPHome Device Builder
Current version: 2025.4.1
Home Assistant
Core 2025.4.4
Supervisor 2025.04.1
Operating System 15.2
Frontend 20250411.0
Network
UniFi OS 4.2.9
Network 9.0.114
.txt   koi-rk-kincony-kc868-a128_logs.txt (Size: 12.57 KB / Downloads: 439)
.txt   default-code.txt (Size: 618 bytes / Downloads: 447)
.txt   full code.txt (Size: 40.64 KB / Downloads: 394)
do you wifi is 2.4G, not use by 5.8G.
you can use your mobile phone work as wifi hot spot, let your KC868-A128 board connect it for a testing.
I get this error code with fixt lan connection maybe you know where the problem could be I have already looked in the github of HA and EspHome its online in esphome builder and can log
Logger: aioesphomeapi.reconnect_logic
Source: runner.py:154
First occurred: 11:08:35 (5 occurrences)
Last logged: 12:02:26
Can't connect to ESPHome API for koi-rk-kincony-kc868-a128 @ 20.20.20.183: Timeout waiting for HelloResponse, ConnectResponse after 30.0s (TimeoutAPIError)
Can't connect to ESPHome API for koi-rk-kincony-kc868-a128 @ 20.20.20.183: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='20.20.20.183', port=6053))]: [Errno 113] Connect call failed ('20.20.20.183', 6053) (SocketAPIError)
Can't connect to ESPHome API for koi-rk-kincony-kc868-a128 @ 20.20.20.183: koi-rk-kincony-kc868-a128 @ 20.20.20.183: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (Home Assistant 2025.4.4) (EncryptionHelloAPIError)
Logger: aioesphomeapi.connection
Source: /usr/src/homeassistant/homeassistant/components/esphome/manager.py:382
First occurred: 11:43:51 (5 occurrences)
Last logged: 14:06:47
koi-rk-kincony-kc868-a128 @ 20.20.20.183: disconnect request failed
Traceback (most recent call last):
  File "aioesphomeapi/connection.py", line 820, in aioesphomeapi.connection.APIConnection.send_messages_await_response_complex
TimeoutError
The above exception was the direct cause of the following exception:
  File "aioesphomeapi/connection.py", line 1026, in aioesphomeapi.connection.APIConnection.disconnect
  File "aioesphomeapi/connection.py", line 838, in send_message_await_response
  File "aioesphomeapi/connection.py", line 824, in send_messages_await_response_complex
aioesphomeapi.core.TimeoutAPIError: Timeout waiting for DisconnectResponse after 10.0s
First occurred: 10:54:24 (11 occurrences)
Last logged: 14:13:04
koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection error occurred: koi-rk-kincony-kc868-a128 @ 20.20.20.183: EOF received
koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection error occurred: koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection lost
koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection error occurred: koi-rk-kincony-kc868-a128 @ 20.20.20.183: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (Home Assistant 2025.4.4)
do you only want use KC868-A128 board work with digital input and digital output using wifi? if YES, i can test it to compile.
Small update
I also have an A64 board, this board does not have this problem.
Can it be the ESP32 chip that breaks i am going to check the voltage input but it must be fine 24v 25A power supply
also can you test the with wifi
ok, i will test with wifi by esphome.
Tested with KC868-A128. here are two yaml file for ethernet and wifi.
.txt   KC868-A128-HA-Ethernet.txt (Size: 40.61 KB / Downloads: 390)
.txt   KC868-A128-HA-Wifi.txt (Size: 40.67 KB / Downloads: 356)
So the esp32 a64 card is stable but the a128 card not can this be a failing esp32
I am going to swap the eth cable
Also i am checking the imput voltage
So update wifi is stable but lan not problem with ethernet chip??
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  #manual_ip:
  #  static_ip: 20.20.20.183
  #  gateway: 20.20.20.1
  #  subnet: 255.255.255.0
  #  dns1: 8.8.8.8
  #  dns2: 1.1.1.1
ethernet not stable?
