DS18B20 temp sensor
Good day how do I connect a DS18B20 temperature sensor to a KC868-A6 so that I can monitor it through smart home app
smart home app not support tuya. you can use tuya app, that can monitor sensor data. just need tuya license, so that can work with KC868-A6
(04-16-2025, 06:53 AM)admin Wrote: smart home app not support tuya. you can use tuya app, that can monitor sensor data. just need tuya license, so that can work with KC868-A6
But how do I connect the sensor to the kc868-a6 controller, where do I connect the Wires
Do you seen the GND, gpio-1 or gpio-2, 3.3V that use for DS18B20.
GPIO-1 means: GPIO32
GPIO-2 means: GPIO33
Ok Thank you very Much
I managed to connect the Temperature sensor and it works perfectly.
Now I have another problem.
I have connected a 0-5v pressure sensor to AI1 now I want DO3 to be switched on when AI1 > than 0.2 and DO3 be switched off when AI1 < 0.19
I have created IFTTT scenes but it doesnt want to trigger DO3 on or off.
Pleas assist
KS868-A6 for temperature measurement with SD16B20:
I need to help. I have a KS868-A6 with SD16B20 sensor and SSD 1306 display and I want show data on display.
I use Arduino IDE.
How I can do it?
Thank's.
this need you write your own arduino code. we have arduino demo source code for DS18B20 and SSD1306. You need to combine these two parts of code together.
