07-02-2025, 02:45 PM
KC868-A8 TCP -Server
07-03-2025, 02:31 AM
you don't need alway send "RELAY-STATE-255" to check state. because even if the relay state changed, it will auto feedback the state message.
07-14-2025, 09:57 PM
(07-14-2025, 09:57 PM)Dm81 Wrote:(07-03-2025, 02:31 AM)admin Wrote: you don't need alway send "RELAY-STATE-255" to check state. because even if the relay state changed, it will auto feedback the state message. I forgot, my problem remains, sometimes it's enough I push 2 or 3 times the switch and the client is disconnected from server with others kincony products connected to my software I don't have this problem thx
07-16-2025, 12:04 AM
do you have only one of KC868-A8? if have another board, you can test with another KC868-A8 board, whether only one have issue.
another way ,can you set another ip address of this board using STATIC IP address.
Online Store: https://shop.kincony.com Alibaba Store: https://kincony.en.alibaba.com/ (07-16-2025, 12:04 AM)admin Wrote: do you have only one of KC868-A8? if have another board, you can test with another KC868-A8 board, whether only one have issue. I have only this KC868-A8, I bought it to try static ip is already set but wifi is impossible to turn off I'm connected in LAN
07-16-2025, 11:15 PM
you can ERASER all ESP32, then download newest firmware: https://www.kincony.com/forum/showthread.php?tid=8267
07-17-2025, 07:45 PM
(07-16-2025, 11:15 PM)admin Wrote: you can ERASER all ESP32, then download newest firmware: https://www.kincony.com/forum/showthread.php?tid=8267 nothing also with new firmware, after 2 or 3 push and client is disconnected from server I have a kc868-A32, I will try with that and I back to you soon thank you
07-17-2025, 09:01 PM
ok, you can test firstly. if it's a hardware issue, we can re send you a new KC868-A8 pcb. now just need to confirm whether is software issue.
07-18-2025, 06:38 PM
(07-17-2025, 09:01 PM)admin Wrote: ok, you can test firstly. if it's a hardware issue, we can re send you a new KC868-A8 pcb. now just need to confirm whether is software issue. I try with kc868-A32, The problem remains My question is, what is the difference between other dvices? In my home network I have 2 KC868 - COLB, 2 KC86-H32, 1 KC868-H16, 1 KC868-D8 and I don have this kind of problem thank you |
