KC868-A8 TCP -Server
#11
(06-24-2025, 11:16 PM)admin Wrote: can you change to 2s for testing, more delay time.
with 2 seconds no problem
do you have an idea the why I receive the message with STATE if I don'd send RELAY-STATE-255
thank you
you don't need alway send "RELAY-STATE-255" to check state. because even if the relay state changed, it will auto feedback the state message.
(07-03-2025, 02:31 AM)admin Wrote: you don't need alway send "RELAY-STATE-255" to check state. because even if the relay state changed, it will auto feedback the state message.
Sorry for my late reply but I was out
I don't send  RELAY-STATE-255, I send only RELAY-SET.....
thx
thx
I forgot, my problem remains, sometimes it's enough I push 2 or 3 times the switch and the client is disconnected from server
with others kincony products connected to my software I don't have this problem
thx
do you have only one of KC868-A8? if have another board, you can test with another KC868-A8 board, whether only one have issue.
another way ,can you set another ip address of this board using STATIC IP address.
(07-16-2025, 12:04 AM)admin Wrote: do you have only one of KC868-A8? if have another board, you can test with another KC868-A8 board, whether only one have issue.
I have only this KC868-A8, I bought it to try
static ip is already set but wifi is impossible to turn off
I'm connected in LAN
you can ERASER all ESP32, then download newest firmware: https://www.kincony.com/forum/showthread.php?tid=8267
(07-16-2025, 11:15 PM)admin Wrote: you can ERASER all ESP32, then download newest firmware: https://www.kincony.com/forum/showthread.php?tid=8267
nothing also with new firmware, after 2 or 3 push and client is disconnected from server
I have a kc868-A32, I will try with that and I back to you soon
thank you
ok, you can test firstly. if it's a hardware issue, we can re send you a new KC868-A8 pcb. now just need to confirm whether is software issue.
(07-17-2025, 09:01 PM)admin Wrote: ok, you can test firstly. if it's a hardware issue, we can re send you a new KC868-A8 pcb. now just need to confirm whether is software issue.
I try with kc868-A32, The problem remains
My question is, what is the difference between other dvices?
In my home network I have 2 KC868 - COLB, 2  KC86-H32, 1 KC868-H16, 1  KC868-D8 and I don have this kind of problem
thank you
