[arduino code examples for B24M]-05 Read free GPIO state
* GPIO Status Monitoring
* This program monitors the status (high or low) of multiple GPIO pins on the ESP32-S3.
* It prints the status of the pins to the serial monitor whenever a change is detected.
* GPIO Pins Monitored:
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 40
* - GPIO 48
* - GPIO 47
* - GPIO 7
* Hardware Requirements:
* - Connect the pins to appropriate devices or pull them to HIGH/LOW for testing
// Define the GPIO pins to be monitored
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_40 40
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_7   7
// Create an array to hold the GPIO pin numbers
const int monitoredPins[] = {
  GPIO_PIN_13,
  GPIO_PIN_14,
  GPIO_PIN_21,
  GPIO_PIN_40,
  GPIO_PIN_48,
  GPIO_PIN_47,
  GPIO_PIN_7
const int pinCount = sizeof(monitoredPins) / sizeof(monitoredPins[0]);
// Store the previous state of the GPIO pins
bool prevState[pinCount] = {false};
  Serial.begin(115200);       // Initialize the serial monitor
  while (!Serial);            // Wait for serial monitor to open
  // Set each monitored pin as input
  for (int i = 0; i < pinCount; i++) {
    pinMode(monitoredPins[i], INPUT);
  Serial.println("GPIO Status Monitoring Started");
    bool currentState = digitalRead(monitoredPins[i]);
    if (currentState != prevState[i]) {
      Serial.print("GPIO ");
      Serial.print(monitoredPins[i]);
      Serial.print(" changed to ");
      Serial.println(currentState ? "HIGH" : "LOW");
      prevState[i] = currentState;
  delay(100); // Delay to reduce serial flooding
arduino ino file download:
.zip   5-free-gpio-state.zip (Size: 924 bytes / Downloads: 245)
.zip   5-free-gpio-state.ino.merged.zip (Size: 181.63 KB / Downloads: 234)
