How to use tasmota for KC868-A16 via PCF8574 IIC extend GPIO
#51
Hello. I used the tasmota32.factory_pcf8574_mode2.zip firmware for the kc868-a16 board. However, the pcf8574 is not displayed in the configuration. Please help me understand what I am doing wrong.
make sure your firmware is enabled PCF8574 version.
(08-19-2025, 01:57 PM)admin Wrote: make sure your firmware is enabled PCF8574 version.
The firmware was downloaded from a nearby discussion thread and described as the latest version of the firmware with "psf8574" compilation. I had previously attempted to compile my own firmware as described in the discussion, but the result was the same: no psf8574 configuration
do you download this one: https://www.kincony.com/forum/attachment.php?aid=642
(08-19-2025, 11:56 PM)admin Wrote: do you download this one: https://www.kincony.com/forum/attachment.php?aid=642
Ok, thank you very much. Please also help me configure the dependence of inputs and outputs. Since the outputs are turned on via the web interface, but not when the input is physically closed.
create RULE for tasmota.
(08-20-2025, 08:33 AM)admin Wrote: create RULE for tasmota.
Спасибо. Дополнительно надо было включить правило (rule1 on)
Is the latest version of Tasmota, which includes PCF8574, available for download anywhere?
if you want newest tasmota firmware, you can download from tasmota official webpage.
(09-18-2025, 01:13 PM)admin Wrote: if you want newest tasmota firmware, you can download from tasmota official webpage.
Hello Smile
The official version does not include PCF8574 support. Nor does it include product-specific software elements.
It cannot be updated online; I tried version 10 and version 12. The OTA update does not work. I think many of us would be very grateful if you could publish an image file containing the latest firmware...
