KC868-A16 integrates Home Assistant via MQTT?
I am using KC868-A16 to control the lighting system and sensors in my house. I see in the documentation that there are instructions on MQTT, but I am not sure if any special configuration (such as firmware adjustment or setting up a separate broker) is required to integrate stably with Home Assistant. In addition, has anyone tested latency or disconnection issues when using MQTT with the KC868-A series?
I hope everyone can share their experiences.
you can use mqtt or ESPHome two different way integrate to home assistant.
