Submit your suggestions and ideas for the product
#31
KC868-AP also is 0-10v output, not use by PWM output.
(10-20-2025, 12:06 AM)admin Wrote: KC868-AP also is 0-10v output, not use by PWM output.
KC868-AP doesn't use PWM?
I can see in the description:
"KC868-AP is a ESP32 16 channel PWM dimmer board"
https://shop.kincony.com/products/kc868-...pwm-dimmer
KC868-AP use by PCA9685 PWM chip, yes, it output PWM signal. i just said, the terminal output is dc 0-10v.
But you can check with this schematic: https://www.kincony.com/download/KC868-AP-schematic.pdf
https://www.kincony.com/images/KC868-AP/...P-1_04.jpg
Based on this drawing, the output of the board seems pwm 24Vdc.
it output support 12v or 24v, according to your power supply.
