E16V3 - Dimensions compatibility with domestic electrical enclosures
The E16V3 can't be nicely integrated in domestic electrical enclosures.
This forces cutting the plastic of the enclosures, which is not nice.
It would be good to have a cover compatible with those standardized enclosures:
- Width equal to a number of standard module (18mm I think)
- Height of the prominent part = 45 mm.
BRs,
Laurent
because the OMRON relay is large, maybe remove the manual control buttons will smaller. But I think the manual control button is important.
Many thanks for your answer.
Manual controls are important, but this is not the issue.
The depth is not an issue.
The issue is the height of the hole in the enclosure.
The prominent part should not exceed 45mm in height (and the OMRON relays would allow that without issue).
I am referring to the dimensions when we look at the device mounted on a DIN rail on a vertical wall:
Height is from your head to your feet.
May be a drawing would explain better.
if you can draw a photo explain it is better. we will improve it.
