04-18-2026, 11:21 AM
Got it, great.
Does h32b support http command?
Http protocol
04-18-2026, 11:27 AM
yes, H32B support HTTP protocol, here is protocol document: https://www.kincony.com/download/KC868-H...ommand.pdf
04-18-2026, 11:40 AM
Which work mode i have to set in h32b?
My H32b has v4.41 firmware. Do i have to update to the last version v5.04?
04-18-2026, 12:16 PM
not need update, v4.41 already support HTTP command.
if you want use H32B with HTTP, not need set to any mode. HTTP is always work.
04-18-2026, 01:19 PM
Does H32L the same thing?
04-18-2026, 08:13 PM
Can you also send a link for last firmware version for h32b!
Thanks.
04-18-2026, 11:47 PM
H32L not support HTTP.
H32B newest firmware: https://www.kincony.com/forum/showthread.php?tid=3323 But make sure your CPU is AT32F xxxxx new model. it at bottom of PCB.
Yesterday, 03:13 PM
I saw in the http commands protocol just the option to turn on or off one relay.
Is there a command to turn on or off multiple relays?
10 hours ago
H32 series product no multi relay control command.
KCS firmware have this command.
| 1 Guest(s) |
