Ethernet static address
I use a Board KC868-A16 Rev1.6.3 with tasmota firmware-en-a16.bin from here. After installation I have two ip-addresses (via dhcp) one for wifi and one for ethernet.
In the console I can change the wifi adress to a static address with the command ipaddress1 xxx.xxx.xxx.xxx , that works fine.
But how can I change the ethernet-address to a static one?
Web UI → Console , you can input these command:
EthIPAddress 192.168.1.100
EthGateway 192.168.1.1
EthSubnetmask 255.255.255.0
EthDNSServer1 8.8.8.8
EthDNSServer2 1.1.1.1
Restart 1
Thank You for the quick reply, but this produces the error message "Unknown command"
https://tasmota.github.io/docs/Commands/...e-commands
The command EthIPAddress is unknown in my version, does that mean, that the compilation I've used (this one) is not ok?
maybe you need enable ethernet function when compile.
